Author Topic: Terminal ends  (Read 8590 times)
Offline burnze
Terminal ends
« on: February 02, 2017, 01:03:32 am »
What are the terminal ends called on the 18 pin connector body for the instrument cluster and where can i buy them
83 gmc crew cab
84 chevy blazer
87 r10 short box
Re: Terminal ends
« Reply #1 on: February 02, 2017, 03:48:16 pm »
um... 73-87 dash cluster pigtail. google it you will see them, and try ebay
Re: Terminal ends
« Reply #2 on: February 02, 2017, 03:49:22 pm »
Offline burnze
Re: Terminal ends
« Reply #4 on: February 02, 2017, 08:21:09 pm »
I guess what im looking for is new pins that go into the cluster pigtail i can find the packard 56 and 58 pins but not the ones for the cluster connector body
83 gmc crew cab
84 chevy blazer
87 r10 short box
Re: Terminal ends
« Reply #5 on: February 02, 2017, 10:06:02 pm »
The OEM terminals were Packard (now Delphi) Type 5 board edge terminals, carrying GM P/N 12004542, which superseded to 12040500.  At one time the OEM terminals were readily available, but have since been discontinued.  There are no aftermarket retail substitutes or suppliers for small quantities.  Delphi still lists the 12040500 as available via minimum special orders of something like 2,500 pieces, give or take.  So, unless you find a local source with some ancient remaining stock (or have a wad of uneeded cash and don't mind having 2,482 pieces left over), a used pigtail maybe your only option.
« Last Edit: February 04, 2017, 08:30:58 pm by bd »
Offline burnze
Re: Terminal ends
« Reply #6 on: February 03, 2017, 12:28:01 am »
Ok thanks thats probabally why im seeing a lot of the cut ones on ebay
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline harcorshe
Re: Terminal ends
« Reply #7 on: February 08, 2017, 09:21:53 pm »
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Re: Terminal ends
« Reply #8 on: February 08, 2017, 09:37:26 pm »
Great find!  Thanks!
Offline burnze
Re: Terminal ends
« Reply #9 on: February 09, 2017, 02:35:38 pm »
Thamks for the info ordered the kit today i have a classic industries catalog they wasnt in there hope they send a new catalog with my order
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline burnze
Re: Terminal ends
« Reply #10 on: February 19, 2017, 11:01:05 pm »
Received the 18 pin instrument cluster kit last week good quality parts and fit well.
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Terminal ends
« Reply #11 on: February 20, 2017, 10:14:03 am »
Good to hear, may need to order one myself
 1986 Chevy K30(under repair)
Offline blazer74
Re: Terminal ends
« Reply #12 on: February 21, 2017, 01:14:16 am »
Would be good to have. Hmmm
