Author Topic: Quiz: Test Your Mechanical Knowledge!  (Read 6558 times)
Offline plik
« on: February 11, 2017, 10:15:03 am »
Can you answer this question:
You're driving your Chevy 350 5.7 TBI down the road. It's a lovely day outside. Suddenly, your engine loses power. You pull your foot off the gas, press again, and everything is fine. It seems like you were running out of gas, but your tank isn't low. You push the pedal down hard to see if it will rev, and everything sounds great, it revs high and you accelerate. A few minutes later, it does it again -- loses power like the fuel just stopped. Pressing on the gas more doesn't help or do anything. You pull our foot off the pedal, press again, and it's fine. Your fuel pump is only five years old, as is the fuel filter. Your TBI has fuel injectors that are only two years old.
What is causing this?
Re: Quiz: Test Your Mechanical Knowledge!
« Reply #1 on: February 11, 2017, 10:52:23 am »
Pick up coil would be my first thought.
« Reply #2 on: February 11, 2017, 11:40:09 am »
Scan it first, check your TPS, check your fuel pressure, check exhaust backpressure.
Offline Timberwolf
« Reply #3 on: February 11, 2017, 04:50:01 pm »
I would take a good look at that five year old filter. It sounds like you are getting a reduced fuel flow to your rail. The filter is passing enough fuel to run the engine under idle, or low load conditions, but when you put the boot to it- there just isn't enough fuel passing through the filter to power the engine.
Offline Dr_Snooz
« Reply #4 on: February 11, 2017, 07:05:15 pm »
I had the same symptoms just before my ICM pooped out and left me stranded.
Offline LTZ C20
« Reply #5 on: February 11, 2017, 07:35:11 pm »
At 5 years, the filter is definitely due for replacement.
LTZ Cheyenne C20
Offline 184Champion
« Reply #6 on: February 17, 2017, 07:54:53 pm »
I would change the fuel filter first. I had something similar to this happen on 2 different TBI set ups. Both of those the fuel sending unit went bad and the vehicle was almost out of gas.
1979 C-10, 2 wheel drive, 350, 700R4, Affordable fuel injection TBI, Pulleys and accessories off a 1990. I always hates multiple belts. Electric cooling fans.
« Reply #7 on: February 23, 2017, 12:32:44 pm »
the rubber hose that connects the fuel pump to the fuel pump assembly could be cracked not allowing the proper amount of fuel.
Offline philo_beddoe
  • 77 C-10
« Reply #8 on: March 02, 2017, 10:40:28 pm »
I would just call VZ or bd. Lol
Offline plik
« Reply #9 on: March 12, 2017, 11:36:52 am »
And the answer was ...
Fuel Filter
Thank you, everyone, for your help. I really appreciate all the assistance I've received from this forum. You guys are great.
