Author Topic: Should these holes be capped off?  (Read 5441 times)
Offline philo_beddoe
  • 77 C-10
« on: July 02, 2017, 12:32:38 pm »
Where do these holes lead to, will water drain out, should i cap them off?
  • 77 C-10
Re: Should these holes be capped off?
« Reply #1 on: July 08, 2017, 09:51:34 pm »
Nobody knows??!?!
« Reply #2 on: July 08, 2017, 09:53:19 pm »
Those shouldn't be there, probably a cover of some sort at one time
« Reply #3 on: July 09, 2017, 07:55:30 am »
Exactly, someone drilled them. Put plugs in if you don't want water to get in there.
  • 77 C-10
« Reply #4 on: July 10, 2017, 02:44:35 pm »
Ok, i know what it was, ziebert rust-proofing was done on the truck, a long long time ago. Now where in the world do i get some black plugs that'll fit? I already sprayed fluid film in there.
« Reply #5 on: July 10, 2017, 04:54:51 pm »
Fluid film is crap, don't waste your money. Take a digital caliper and measure the holes and order a set of body plugs.
  • 77 C-10
« Reply #6 on: July 11, 2017, 08:07:08 pm »
Ok, i'll ask...why is fluid film crap, is there something better? I'll look into those body plugs.
« Last Edit: July 11, 2017, 08:13:15 pm by philo_beddoe »
