Author Topic: Manual Hub not engaging  (Read 10791 times)
Offline srozell
    • My 1980 Chevy
« on: July 05, 2017, 02:05:03 pm »
If I disassemble, then reassemble the hub, it engages and remains engaged.
When I switch the hub to "FREE" it disengages as expected.
When I switch back to "LOCK" it no longer engages, and makes a clicking sound when the wheel turns.
Inside I found wear on the following components. I've also enclosed a picture of the shop manual for reference and clarity.
Should the axle shaft sleeve and ring really be wearing on the outer clutch retaining ring?
Should I be replacing the manual hubs, or is there something else I should be doing first?
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
Re: Manual Hub not engaging
« Reply #1 on: July 05, 2017, 06:14:17 pm »
I would replace the locking hubs
Offline srozell
    • My 1980 Chevy
« Reply #2 on: July 05, 2017, 07:37:15 pm »
That's kind of what I was thinking. I cleaned the pieces up a bit, removed the burrs and such, and it engages now, but I feel like it's only a stop gap.
1969 K20 Step Side
Offline ehjorten
« Reply #3 on: July 06, 2017, 09:22:12 am »
On that note...I understand you can't get those Spicer hubs anymore?  I have them on my 1-ton crew cab.  What is the standard for replacement...Dynatrac...Yukon?
-Erik-
Offline srozell
    • My 1980 Chevy
« Reply #4 on: July 06, 2017, 02:27:43 pm »
I was going to go with the Warn 20990. Is there any reason not to?
https://www.warn.com/truck/hubs/premium_application_chart.jsp
1969 K20 Step Side
Offline jetman
    • Squarebody Referance Library
« Reply #5 on: July 09, 2017, 03:44:13 pm »
I use 'em.  Work great, engage easily.  Don't need the spindle nut kit.
Offline srozell
    • My 1980 Chevy
« Reply #6 on: July 09, 2017, 07:54:32 pm »
Thanks!
1969 K20 Step Side
Offline srozell
    • My 1980 Chevy
« Reply #7 on: July 11, 2017, 05:40:01 pm »
I installed the Warn 20990 hubs today. It generally went without a hitch. Someone had dented one of the wheel hubs a little so I needed to do some die-grinding and subsequent clean-up so the hubs would fit well, but other than that, installation was seamless.
1969 K20 Step Side
Offline jetman
« Reply #8 on: July 11, 2017, 10:38:43 pm »
That was fast!  Should I have known you were in process I would have mentioned.
Pro Tip #482 - use a pair of pliers to bend in one end of the hub retaining snap ring.  Makes it much easier to remove the hubs for bearing service at a later date.
Offline srozell
    • My 1980 Chevy
« Reply #9 on: July 13, 2017, 09:58:11 pm »
I never had a problem getting them out, but it's a good tip.
1969 K20 Step Side
