Author Topic: a/c swap  (Read 5267 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
a/c swap
« on: October 12, 2017, 07:32:01 pm »
i have a 1986 4.3 v6 AT 2wd custom deluxe. currently does not have a/c. My question im looking at buying a 1983 custom deluxe with a 350 v8 AT 2wd. It has factory air and my 86 does not. Will everything swap over or is there anything special i must purchase?
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Re: a/c swap
« Reply #1 on: October 13, 2017, 06:00:21 am »
It will swap however you will have to do some work to the firewall. Using the donor as a template you can make the necessary modifications.
Offline Smitty31
Re: a/c swap
« Reply #2 on: October 13, 2017, 05:13:30 pm »
i thought i may have to do some cutting on the firewall that is good info thanks.
