Author Topic: Valve cover question  (Read 6536 times)
Offline Gearhead427
« on: February 22, 2006, 09:47:00 pm »
Hello I'm new here and have a really stupid question I have a 81 Gmc with a 305 and the valve covers leak like crazy well i got the gaskets and was about pull it apart but saw that the pass side valve cover is partly covered by the EGR valve and was wondering if i need to remove this to replace the valve cover gasket
Re: Valve cover question
« Reply #1 on: February 23, 2006, 07:29:00 am »
You should be able to sneak it by. its tight but doable.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: February 23, 2006, 07:43:00 am »
If a 305 is similar to a 350, you will have no problem. I have taken my valve covers off many times w/out worrying about the EGR valve.
If a 305 is a little different, there are only two bolts holding it down...maybe just loosen them a little, being careful w/ the EGR gasket, and push it out of the way.
SgtDel
Offline Gearhead427
« Reply #3 on: February 23, 2006, 07:53:00 am »
Thanks for the replies guys i'll try to get it out in the next day or two. :D
