Author Topic: tranny question  (Read 6519 times)
Offline 85silverado
tranny question
« on: February 24, 2006, 12:30:00 am »
I posted in drivetrains but no luck. Does anyone know the procedures of replacing the seal in the shift shaft on a 700R4?
Offline 123 pugsy
Re;Tranny
« Reply #1 on: February 24, 2006, 12:36:00 pm »
It appears as though none of us has had this problem.:|
Pugsy
76 C10 LWB
TPI 350
Offline 85silverado
tranny question
« Reply #2 on: February 24, 2006, 01:37:00 pm »
I don't know why no one else has had this problem, I have seen it at the dealership many times, just never have fixed one.
Shift Shaft seal
« Reply #3 on: February 24, 2006, 03:32:00 pm »
It's easy. I have the tool to do it but you really don't even need the remover installer to do it. Remove the shift linkage and pry the old seal out using a small screwdriver or cotter pin tool and drive the new one in with a socket. Make sure you lube the new seal with either vaseline or atf.
Offline 85silverado
tranny question
« Reply #4 on: February 25, 2006, 02:58:00 am »
Thanks for the advice. I knew there couldn't be much to it, just didn't want to screw anyhthing up.
