Author Topic: How to remove Part  (Read 3923 times)
Offline AmericaMade
How to remove Part
« on: January 26, 2018, 07:30:30 pm »
Just wondering how to remove this circled area.
Do I also have to remove the AC lines just to replace this gasket?
https://ibb.co/gHuLKG
« Last Edit: January 26, 2018, 07:34:19 pm by AmericaMade »
1983 C10 Scottsdale 383 Stroker TH/350 Holley 850 Double pumper carb
Offline FlatBlack77
Re: How to remove Part
« Reply #1 on: January 26, 2018, 08:43:04 pm »
that is the cruise control vacuum canister whatyacallit if i am not mistaken
If I remember correctly its mounted on a tab that is held on by an intake manifold bolt. Or a bolt on the back of the head. Its been 4 years since i took one off
« Reply #2 on: January 27, 2018, 07:12:13 am »
Cruise Control Servo
Offline NCali
« Reply #3 on: February 17, 2018, 08:57:13 pm »
There are two 3/8 bolts behind the head that are impossible to remove with the engine in the vehicle. there are also three screws holding it to the bracket behind the servo
good luck
Black Labs Matter
