73-87 Chevy & GMC Trucks
How to remove Part
Topic: How to remove Part (Read 3921 times)
AmericaMade
How to remove Part
January 26, 2018, 07:30:30 pm »
Just wondering how to remove this circled area.
Do I also have to remove the AC lines just to replace this gasket?
https://ibb.co/gHuLKG
Last Edit: January 26, 2018, 07:34:19 pm by AmericaMade
1983 C10 Scottsdale 383 Stroker TH/350 Holley 850 Double pumper carb
FlatBlack77
Cheap Fast Reliable - Pick 2
Re: How to remove Part
January 26, 2018, 08:43:04 pm »
that is the cruise control vacuum canister whatyacallit if i am not mistaken
If I remember correctly its mounted on a tab that is held on by an intake manifold bolt. Or a bolt on the back of the head. Its been 4 years since i took one off
January 27, 2018, 07:12:13 am »
Cruise Control Servo
NCali
February 17, 2018, 08:57:13 pm »
There are two 3/8 bolts behind the head that are impossible to remove with the engine in the vehicle. there are also three screws holding it to the bracket behind the servo
good luck
Black Labs Matter
How to remove Part
