Author Topic: Lug nut and stud Just spins  (Read 13651 times)
Offline AmericaMade
« on: February 02, 2018, 03:26:45 pm »
Today I figured I’d put my new center caps on. 20min right? Wrong.
One lug stud decided to come loose it appears.
This stud was already replaced prior to me purchasing the truck. 83’ C10 Scottsdale shorty
I finger tightened all the lug nuts and proceeded in the star pattern with the torque wrench starting 30, but at that point it just started spinning.
I think the stud came loose. Now the lug nut is stuck. any ideas how to get it off?
I tried putting pressure on it and using channel locks to get it to go but no luck.
Link to video:
https://streamable.com/uk5wn
« Last Edit: February 02, 2018, 03:29:25 pm by AmericaMade »
1983 C10 Scottsdale 383 Stroker TH/350 Holley 850 Double pumper carb
Re: Lug nut and stud Just spins
« Reply #1 on: February 02, 2018, 04:10:16 pm »
Take all of the other lug nuts off and use the wheel to apply outward pressure. Use your impact to zip it off and reset the stud.
Offline AmericaMade
« Reply #2 on: February 02, 2018, 04:22:34 pm »
Dont have an impact (please no bully) yet.
 is it still possible w/out one?
« Reply #3 on: February 02, 2018, 04:24:18 pm »
Do yourself a favor and invest in an impact gun. If you don't have a compressor you can buy a cordless one or even an electric one. You can try or just take it to a shop, they'll probably fix it for under $50 bucks.
Offline AmericaMade
« Reply #4 on: February 02, 2018, 05:09:10 pm »
Yeah I figured... thanks for the input
Offline Captain Swampy
  • Wisconsin
« Reply #5 on: February 02, 2018, 08:26:33 pm »
Try a grinder. Do one side, then spin a half turn and do the other. Pry it out as far as possible. You need a new stud anyway. After grinding both sides of the nut, a hammer and chisel should finish it off.
Offline PBritty
  • Newbie, but working on cars for 30 years.
« Reply #6 on: February 03, 2018, 02:04:24 pm »
Grind it
PBritty
North Georgia
1986 Silverado K10 (85% Complete)
1986 Silverado K10 (35% Complete)
Offline AmericaMade
« Reply #7 on: February 03, 2018, 03:23:20 pm »
How? I dont have much room to get to the stud. Or do you mean just grind the nut, basically damaging the lug nut?
Offline AmericaMade
« Reply #8 on: February 03, 2018, 04:04:19 pm »
Does anyone know whay length stud this might be? 84’ C10
« Reply #9 on: February 03, 2018, 04:15:46 pm »
think thats going to depend on your lug nuts. cant see the video but one you get the wheel off measure another lug and see how much you can see sticking out of the hub or the threads then go to the local parts store and compare it to what they have
Offline AmericaMade
« Reply #10 on: February 03, 2018, 04:19:28 pm »
Sounds good... ordered a dremel will use this to remove the dang thing.
For the cost of parts and my time it’s probably cheaper going to a shop 🤣🤣
« Reply #11 on: February 03, 2018, 04:38:07 pm »
well considering the stud and lug are hardened youll have a heck of a time with a dremel. i know my dad years ago when i cross threaded a stud took a socket and extension and jumped on it a few times to break the stud.
Offline 68post
« Reply #12 on: February 03, 2018, 10:12:23 pm »
I've had this happen, I removed the axle and welded the stud to remove the nut.
Offline AmericaMade
« Reply #13 on: February 04, 2018, 09:11:13 am »
I figure I may be able to get enough clearance to get at the stud to use the dremel. If not I’ll just snap it like you said. Thats was my neighbors suggestion, get a bar on it and jump to snap it.
Ill give it a go post back..
Offline AmericaMade
« Reply #14 on: February 05, 2018, 05:56:39 pm »
Just to update. I removed the stud by getting a socket and my breakerbar, thought the breaker bar would break, it didnt. Proceeded going up and down until the nuts thread basically flattened and it slid off. The stud didnt break. Then another stud had to replaced as the nut on that one was stuck as well, squealed like a pig coming off. They are stripped as heck...
I may just replace all of them since I am at. Will also replace the shoes on both rear wheels.
« Last Edit: February 06, 2018, 07:22:43 am by Irish_Alley »
