Author Topic: ridge reaming cylinders???  (Read 9578 times)
Offline 74stepside
« on: June 28, 2006, 09:15:00 pm »
is it always necessary to ream the top of the cylinders prior to pistion removal?? im bringing my block to the machine shop to have it rebuilt and my buddy said he'd help me take the crank and pistons out i just wasnt sure   if reaming was a must...this is my first time taking a motor apart and i just wanted to make sure i did it right..
Offline 1976Scottsdale
Re: ridge reaming cylinders???
« Reply #1 on: June 28, 2006, 09:02:00 pm »
I have never reamed cylinders before removing the pistons myself.  That is just me though.  I would think it would be hard to do the reaming with the pistons still in.
« Reply #2 on: June 28, 2006, 10:05:00 pm »
If there is a severe ridge yes ream it. If not don't bother.
Offline Z28 c10
« Reply #3 on: June 29, 2006, 07:36:00 pm »
If your pulling the crank and all with the block on a stand, why don't you just push em through the bottom of the cylinders?? Might be a dumb question, but who knows??
 JayTater
 Z28 C10
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: June 30, 2006, 01:07:00 am »
Jay is right.  push those bad boys down throught the bottom.  I have honed the bores to get rid of the top lip of the bores after the pistons have been removed.
If you are getting the block bored .30 over or .40 over of whatever, you dont' need to hone it.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Offline 74stepside
« Reply #5 on: June 30, 2006, 06:11:00 pm »
alright thanks for the info..im new at this i wasnt sure if the pistons could be removed from the bottom or not... i am getting a hone done anyway so that should take care of the ridge...i just bought a engine kit from a company called fast engine parts ..prices are pretty good heres the link if anyones interested....
www.fastengineparts.com/p...php?id=269
Offline 123 pugsy
Re: Re: ridge reaming cylinders???
« Reply #6 on: June 30, 2006, 06:29:00 pm »
Cover the connecting rod studs with pcs. of plastic hose or fuel line before lifting out the crank to avoid scratching the crank journals.
Pugsy
76 C10 LWB
TPI 350
Offline Z28 c10
« Reply #7 on: June 30, 2006, 07:32:00 pm »
if your re-using the old crank, you can do an old hillbilly trick to see what kind of shape the journals are in. chances are you may have to get er turned or polished but check this anyways. Take an old penny and rub it across the bearing surfaces, small particles of copper will be left in the deep scratches. Don't worry about damaging the crank with the penny neither, coppers too soft to damage the steel or iron, whichever one you have.
 JayTater
 Z28 C10
Online Mr Diesel
  • Aaron
reaming
« Reply #8 on: July 01, 2006, 04:04:00 pm »
If the rings have worn the cylinder significantly you may have to ream the top ridge in order to get the piston out. If there is much of a ridge the the rings will catch when you try to remove them.
- Mr Diesel
'76 C30 Crew 6.2
Edited by: Mr Diesel at: 7/1/06 3:19 pm
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Re: reaming
« Reply #9 on: July 03, 2006, 06:23:00 pm »
If the rings catch, the bottom of a Blue Point ball pien hammer works well to knock the pistons out... also works on siezed pistons.
Offline roundedline
Re: reaming
« Reply #10 on: July 05, 2006, 05:04:00 pm »
you cannot remove all the pistons from the crank side of the block...  If I remember correctly Only #1 and #8 can be removed this way...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
