Author Topic: Driveshaft Help  (Read 7420 times)
Offline buter1ma
Driveshaft Help
« on: December 22, 2019, 01:15:37 pm »
I have a 86 C10 long bed with two piece driveshaft. I am going to swap in a 700R4. Will I need to go to a one piece or what length from trans to center support bearing do I need?
Re: Driveshaft Help
« Reply #1 on: December 24, 2019, 08:21:09 am »
depending on what trans/tail shaft you have now you may or may not have to do anything
Offline buter1ma
Re: Driveshaft Help
« Reply #2 on: December 24, 2019, 09:25:04 am »
Its is a three on the tree manual transmission. I believe the length will have to change.
Offline JohnnyPopper
  • Old Goof
Re: Driveshaft Help
« Reply #3 on: December 26, 2019, 03:25:14 pm »
I doubt your 3-speed is 30" long, but I have seen some with a long tail section.
Is the output shaft the same in size/splines? May not be...
1980 C-10 under construction
Re: Driveshaft Help
« Reply #4 on: December 27, 2019, 08:30:34 am »
Use this website as a tool and to find an inexpensive option. Use a one piece shaft.
http://www.car-part.com/cgi-bin/search.cgi
