Author Topic: TPI Injection  (Read 12878 times)
Offline 123 pugsy
TPI Injection
« on: September 30, 2006, 09:58:00 pm »
I'm going to check out a TPI from a 5.7 Litre T/A. It appears that the 2 fuel line fittings have been cut off. Can these be fixed?
Pugsy
76 C10 LWB
TPI 350
Re: TPI Injection
« Reply #1 on: October 01, 2006, 09:05:00 am »
Yes you can fix the fuel lines however I hope you're getting an ECM, harness and all of the sensors with it too.
Offline 123 pugsy
Re: TPI Injection
« Reply #2 on: October 01, 2006, 10:11:00 am »
Here's what's included:
I know I will need a Knock sensor.....do you see anything else that may be missing?
It also comes with a steering colunm and key for the VATS security.
Thanks,Pugsy
Edited by: 123 pugsy at: 10/1/06 10:16 am
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: TPI Injection
« Reply #3 on: October 02, 2006, 02:13:00 pm »
Is that the WHOLE wiring harness.  I would get the ALDL section if it isn't there.  Plus the throttle cables if availible.  The air cleaner and piping.  Especially if it is MAF.
Is everything labeled?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 123 pugsy
Re: TPI Injection
« Reply #4 on: October 02, 2006, 06:36:00 pm »
I got a lot more wiring than you see there.I got the whole fusebox and a bunch more.Some have been cut.
No throttle cable.
Its a speed density system.
Everything is not labelled,but the guy threw in a Haynes manuel for the Trans Am
Edited by: 123 pugsy at: 10/2/06 5:44 pm
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: TPI Injection
« Reply #5 on: October 03, 2006, 02:19:00 pm »
I was hoping you were going to say that there is more.
Should be able to find a cable though.
Don't need the duct if it is MAP...
Project Su
Jimmy 2WD Project
Offline 123 pugsy
Re: TPI Injection
« Reply #6 on: October 03, 2006, 08:13:00 pm »
Tracking down parts is half the fun.;)
What's the ALDL stand for?
Edited by: 123 pugsy at: 10/3/06 7:15 pm
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: TPI Injection
« Reply #7 on: October 03, 2006, 11:17:00 pm »
Offline 123 pugsy
Re: TPI Injection
« Reply #8 on: October 04, 2006, 04:18:00 am »
Is that the part that you connect the scan tool up to?
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: TPI Injection
« Reply #9 on: October 04, 2006, 08:17:00 am »
Offline 123 pugsy
TPI
« Reply #10 on: October 04, 2006, 10:08:00 am »
I'm sure its in my wiring mess somewhere.There's a bunch of stuff I don't recognize. I gotta go thru it.I'm sure I'll have a few more questions on this later.
Thanks, Pugsy
Pugsy
76 C10 LWB
TPI 350
