Engine/Drivetrain
Battery lugs
Topic: Battery lugs (Read 5197 times)
Redneckchevy
Battery lugs
December 03, 2006, 12:13:00 am »
Ok ...Let me no if im right to solder new lugs on battery cables ..Put a dab of flux on the inside of the lugs put the lug on the cable heat it up and solder as normel right? just wanting to no if i need the flux or not?
123 pugsy
Re: Battery lugs
December 03, 2006, 06:12:00 am »
Yes,you need flux.
Pugsy
76 C10 LWB
TPI 350
Blazin
Blazin new trails!
Re: Battery lugs
December 03, 2006, 07:04:00 am »
I usually put the flux in the wire. Losen the wind up a bit and dip it in the flux. I clean the inside of the lug with a battery term wire braush and some brake clean, then I cut a few little peices of solder and drop them into the lug. Hold the lug in some vise grips and heat it till the solder melts. Then stuff the wire in and hold it till it cools.
Re: Battery lugs
December 03, 2006, 10:04:00 am »
You should also crimp lugs. There is a large crimping tool for large connections. It's tough to get a good solder bond on large cabling so after you apply as Blazin suggested a crimp should be made using a large battery lug crimper.
www.ancorproducts.com/Products/Tools_Meters/pdf/96.pdf
I have the 701010 and works great
⌠ŻŻŻŻŻ' [☼===☼]
Redneckchevy
lugs
December 03, 2006, 12:29:00 pm »
i thank every one for the help i got it
Blazin
Blazin new trails!
Re: Battery lugs
December 04, 2006, 05:04:00 am »
I now have the use of a crimping tool , but have never had one that I made before come apart. One of my old trucks which is now a parts truck the terminal broke off the other day, but it was due to the wire coroding away. Negitive terminal is still holding strong going on ten years.
Engine/Drivetrain
Battery lugs
