Body, Glass & Paint
Body Mount Bushing Shims
Topic: Body Mount Bushing Shims (Read 5514 times)
Ronno6
Elder Student
March 08, 2021, 11:08:21 am »
The body mount bushings for my 84 C10 came with 1/8" thick shims to sot atop the bushings.
My truck did not have these from the factory.
Does that mean that I do not need to install the shims with the replacement bushings?
You can lead a man to water, but yoiu can't keep him from pissing in it.
blazer74
Re: Body Mount Bushing Shims
March 11, 2021, 11:13:43 pm »
They are for body alignment. Use them if you need them to maintain your gaps and door alignment.
If your gaps are good now and doors close smoothly I’d go back with what came out and go from there.
Factory used them when needed.
JohnnyPopper
Old Goof
March 14, 2021, 03:51:11 pm »
They probably are for body alignment, but if your truck is the step side in your avatar, there is no body alignment like you would see on a fleet.
Really don't see how doors are involved with cab mount bushings. They are aligned within their space of existence usually with a lot of bad words included.
Tip: look for VZ's method of drilling two small holes through your door bracket into the door frame. When reinstalling the door, pin the holes before you tighten the screws.
That is assuming you're happy with the alignment first
1980 C-10 under construction
Mike81K10
Site Supporters
March 14, 2021, 10:04:29 pm »
As JP said, "Really don't see how doors are involved with cab mount bushings."
I have attached a picture of the hardware used with my 1981 K10 cab bushings and Bushings, same for all four.
Last Edit: March 14, 2021, 10:07:14 pm by Mike81K10
March 16, 2021, 05:59:40 pm »
If you want nice body lines, you need to factor in your cab and radiator support bushings. Whatever required shims or spacers are needed to make it right should be used. Door to fender body lines are impacted by the installation of the mounts. You can spot them a mile away when they are off.
Mike81K10
Site Supporters
March 16, 2021, 08:42:12 pm »
Brilliant point VZ.
JohnnyPopper
Old Goof
March 16, 2021, 11:29:04 pm »
Having said that, the line traveling from the doorjamb to the rear of the cab, just above your key tumbler on the door, is the only true benchmark elevation you can rely on.
Draw a straight line from that point forward and shim/de-shim to the perfection you seek.
Use a surveyors device if you have to.
Both side of course
Then hope your grill is level
Body, Glass & Paint
