Author Topic: 1984 K5 Blazer 4x4 build  (Read 59667 times)
Offline mercado1211
Re: 1984 K5 Blazer 4x4 build
« Reply #60 on: April 16, 2022, 11:15:08 pm »
Here we have cracks in the frame from previous owner drilling into the frame after busting the top off the original mount. I welded, filled the cracks rebuilt and relocated the mount to the top of the frame and fabbed this strap to support the side of the shock. Did this to both sides, they both had stress fractures at or near shock mounts.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #61 on: April 16, 2022, 11:16:19 pm »
Passenger side.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #62 on: April 16, 2022, 11:17:45 pm »
Here’s the engine going in for the second time.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #63 on: April 16, 2022, 11:21:49 pm »
Here it is after the engine came out the second time. Wheels are 15x10 American racing Baja type wheel, with Cooper 33/12.5/15 MT’s.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #64 on: April 16, 2022, 11:29:51 pm »
Drove it a few times today, trying to get all the bugs worked out. Trying to determine what else it needs to be safe on the road. Brakes felt spongy, I rebuilt the rear drums and think I got some air in them from opening up the lines. Also doing some tuning on the carburetor and ignition timing. It’s running about 20” of vacuum so that’s probably good. Have the vac advance line into the upper port and seems to run and shift better than full vacuum side (driver side).
1984 k10 LWB
1984 k5
1979 C10 SWB
Online VileZambonie
« Reply #65 on: April 17, 2022, 10:01:50 am »
Did you determine what the knock was?
Offline mercado1211
« Reply #66 on: April 17, 2022, 11:29:30 am »
I still haven’t. The machine shop went through the block and said cylinder 5 was a little tight and honed it again. They checked the clearances on the block and crank and said it was good. It picks up good oil pressure. The only thing I can think of is a bad lifter or needs an oil change. We put it together with oil and lithium grease so it may need to burn all that out and have fresh oil. It’s not a tick either, it’s a loud rap.
My wife’s uncle is a mechanic and used to be a machinist (he put it together and I helped), he said it might be pinging from low octane fuel. I’ve heard pinging before and it’s louder than that. I pulled each plug wire off one by one and ran it and it doesn’t change the knock sound.
I don’t know at this point. I figure just run it till it does what it’s going to do.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline Mike81K10
« Reply #67 on: April 17, 2022, 01:49:30 pm »
Could have a problem with your crank or crank bearings, rod bearings, push rod, or lifter/adjustment.
Offline mercado1211
« Reply #68 on: April 17, 2022, 02:10:27 pm »
We put new main bearings in, new rod bearings, all the clearances seemed to have checked out. Everything was spec’d be the machine shop. I’m leaning towards rocker adjustments now, or a lifter. Pushrods we’re straight. Runs fine other than loud knock. Seems quieter on cold start up and louder when it gets to operating temperature.
Thanks for the reply.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline JohnnyPopper
  • Old Goof
« Reply #69 on: April 17, 2022, 02:40:29 pm »
Quieter when the oil is cold and move viscous. Makes sense, most likely a lifter.
I've seen Rislone work wonders.
BTW, LOOKING GOOD!!!
1980 C-10 under construction
Offline mercado1211
« Reply #70 on: April 17, 2022, 02:49:06 pm »
Hey there you are! Thanks Johnny!
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline Shifty
  • I bleed Bowtie red...
« Reply #71 on: April 18, 2022, 09:09:22 am »
Keep in mind that almost all lifters nowadays are from China.  :-[
98 C2500 ext cab longbed
Offline mercado1211
« Reply #72 on: April 20, 2022, 09:43:56 pm »
I think I’m going to pull the driver’s side lifters out this weekend and have a look at them. If any of them don’t look right I’ll take them apart and check them out. Maybe I’ll just take them apart and clean them.
1984 k10 LWB
1984 k5
1979 C10 SWB
Online VileZambonie
« Reply #73 on: April 21, 2022, 05:15:58 pm »
What brand lifters did you go with? Roller or regular hydraulic?
Offline mercado1211
« Reply #74 on: April 21, 2022, 06:03:16 pm »
Not sure of the brand, they’re hydraulic roller lifters, they guy who built the motor the first time around doesn’t answer my calls. I was trying to get that info from him. We put the same ones back in after it was built again.
1984 k10 LWB
1984 k5
1979 C10 SWB
