Author Topic: 1984 K5 Blazer 4x4 build  (Read 59677 times)
Offline mercado1211
Re: 1984 K5 Blazer 4x4 build
« Reply #30 on: July 27, 2021, 11:08:46 pm »
The fenders were more of the same, they needed filler to straighten out, also had to take them mostly bare metal since these were donor  fenders from the late 80’s with adhesion problems. I hope I don’t have any issues with them as far as paint. This is as far as I am now, I’ve got a bunch more pics and left out a ton of the build like wiring the electric fuel pump, fuel tank install; I can post that if any body wants to see it.
Thanks for looking, I appreciate it.
1984 k10 LWB
1984 k5
1979 C10 SWB
« Reply #31 on: July 28, 2021, 07:09:50 am »
Looking good! I just did a lot of the same with mine.
Offline mercado1211
« Reply #32 on: July 28, 2021, 07:14:43 am »
Thanks, I saw a full convertible top somewhere on here and I think was yours, nice.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #33 on: July 28, 2021, 10:11:24 am »
What I didn't mention is that many many hours went into applying filler blocking, applying filler blocking again blocking again. More primer and looking for high and lows by blocking again with a guidecoat, then more primer, then hopefully good enough to go to the painter for final paint.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline 1980K20
« Reply #34 on: July 28, 2021, 09:56:40 pm »
Wow, what a nice job so far!
Sent from my SM-G965U using Tapatalk
1952 International L112 - waiting for EV conversion
1967 Camaro - 250 six cyl, 200-4R
1980 K20 4x4 Fleetside - 350 SBC roller Cam, TH350
Offline mercado1211
« Reply #35 on: July 29, 2021, 07:55:03 am »
Thanks man,
Appreciate it.
1984 k10 LWB
1984 k5
1979 C10 SWB
« Reply #36 on: August 15, 2021, 08:13:40 pm »
Nice Work!
Offline mercado1211
« Reply #37 on: August 15, 2021, 11:27:41 pm »
Thanks man,
Appreciate it, I’ve been getting it ready to take to the painter. Here it is a little further along. More blocking revealed high spots that I had to fix, especially the door.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline frotosride
    • WFO CONCEPTS
« Reply #38 on: August 19, 2021, 07:39:58 pm »
Looking great. When I saw the windshield channel I felt your pain. Until you've done it there's no way to know the time to make those small pieces.
I hope my Blazer turn out half as good. Keep it coming. Hopefully paint jail is a short sentencing.
Offline mercado1211
« Reply #39 on: August 20, 2021, 10:32:25 pm »
Thanks man,
Appreciate it. Yeah, I figured somebody out there’s had to have seen something like this given the channel is a common rust area. I just dropped it with the painter today. I’ll post some pics when the paint and liner is done.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline 1980K20
« Reply #40 on: August 22, 2021, 12:22:12 pm »
Nice work. Fyi My painter used a metalized epoxy on the window channel to both fill in pin holes and to prevent future rot.
Offline mercado1211
« Reply #41 on: August 22, 2021, 05:05:45 pm »
Thanks, appreciate it.
I cut out all the rotted metal in small pieces and fabricated each piece of the cut piece by piece. I then tacked it in place piece by piece to hopefully stay as close to the overall true form. The entire lower corners of the windshield channel on both sides were pretty much rebuilt. I had concerns with the amount of heat in the area and how it might affect the overall integrity of the piece, went slow and tried to give it enough time to to cool between tacks.
Guess we’ll see what happens.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #42 on: December 09, 2021, 11:34:41 pm »
Paint is finished.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #43 on: December 09, 2021, 11:35:45 pm »
Fine tuning these body lines.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #44 on: December 09, 2021, 11:41:40 pm »
Note the ratchet strap, used it to close it up and tightened the fender. I used a strap on the other side as well to pull the core support out to fine tune the gaps. This side was a little more defiant. Not sure if it’s a body mount issue somewhere or just the way it is. The lower door to fender gap is wider than up top. This is as close as I could all the components to work and look decent. Right, left fenders and hood.
1984 k10 LWB
1984 k5
1979 C10 SWB
