Author Topic: Ready to be blasted  (Read 95598 times)
Offline Swampyankee74
  • Keep em alive
Re: Ready to be blasted
« Reply #60 on: March 04, 2023, 10:02:07 am »
Yes, my motor mounts and tranny mount all line up where she is supposed to
  • Keep em alive
« Reply #61 on: March 04, 2023, 10:09:25 am »
The threaded hole for the ball is farther forward and higher on the lakewood bellhousing.  It came out of a 69 chevelle.  I'm guessing the had different orientation.  I think I'm gonna weld a piece to the bellhousing bracket and drill and tap it in the proper location
« Reply #62 on: March 04, 2023, 10:12:07 am »
I would suggest you mockup the Zbar on the frame side, and connect everything, then bullseye where the engine side ball stud would go. Drill and tap the hole.
  • Keep em alive
« Reply #63 on: March 04, 2023, 10:15:10 am »
That is the plan. There is just no metal where it should be. Got to add a piece
« Reply #64 on: March 04, 2023, 10:20:38 am »
Use could use the existing holes and the boss near the oil filter to make a bracket.
  • Keep em alive
« Reply #65 on: March 04, 2023, 10:22:51 am »
That's an idea too. I'm brain storming, I'll post some pics of the product
  • Keep em alive
« Reply #66 on: March 04, 2023, 01:58:06 pm »
Problem fixed. I hope...
Sent from my SM-S515DL using Tapatalk
« Reply #67 on: March 04, 2023, 06:43:46 pm »
Git r done  8)
  • Keep em alive
« Reply #68 on: March 05, 2023, 06:15:27 pm »
She is back together. Motor and tranny are locked in. Everything appears as though it is gonna work nicely.
  • Keep em alive
« Reply #69 on: March 05, 2023, 06:16:07 pm »
Pic
Offline Shifty
  • I bleed Bowtie red...
« Reply #70 on: March 06, 2023, 08:38:26 am »
Nice ingenuity!  8)
98 C2500 ext cab longbed
Offline JohnnyPopper
  • Old Goof
« Reply #71 on: March 06, 2023, 07:56:03 pm »
Best MacGyver move I've seen lately... 8)
1980 C-10 under construction
  • Keep em alive
« Reply #72 on: March 18, 2023, 02:42:21 pm »
Just an update.  Headers are on. All new tierods, idler arm and pitman arm. Converted over to powersteering, purchased a rebuilt Cardone steering box and new lines
Offline Shifty
« Reply #73 on: March 18, 2023, 04:12:09 pm »
Looks great Man!
  • Keep em alive
« Reply #74 on: March 18, 2023, 06:10:16 pm »
Thank you! It is coming along little by little.
