Author Topic: Ready to be blasted  (Read 95568 times)
Offline Swampyankee74
  • Keep em alive
Re: Ready to be blasted
« Reply #90 on: April 23, 2023, 03:53:54 pm »
That's my boy. He's 5. He's learning for when we build him a truck
Sent from my SM-S515DL using Tapatalk
Offline JohnnyPopper
  • Old Goof
« Reply #91 on: April 23, 2023, 04:52:04 pm »
Handsome lad!
Good time to start. ;)
1980 C-10 under construction
  • Keep em alive
« Reply #92 on: April 23, 2023, 05:01:36 pm »
Trying to remove my steering column.  It is a 3 speed standard on the column.  Trying to remove the shifting ears. First on came right off. Second not so much. It is connected directly to the shifter on the column.  How do I release this? Is it up top in the cab or down here at the ear. Any help would be appreciated
  • Keep em alive
« Reply #93 on: April 23, 2023, 05:03:05 pm »
Pic
  • Old Goof
« Reply #94 on: April 23, 2023, 05:08:21 pm »
was the other one keyed?
Apply some heat
  • Keep em alive
« Reply #95 on: April 23, 2023, 05:11:34 pm »
No, the other one was controlled by the same part I can't get off
  • Keep em alive
« Reply #96 on: April 23, 2023, 05:12:30 pm »
I might just pull the big rubber boot. My new/used column has a good rubber on it all ready
Offline Mike81K10
« Reply #97 on: April 23, 2023, 05:18:51 pm »
I have never removed an Automatic or Column shift steering column. However looking at the picture I see a small hole at the top , is it a spring load clip? Is the picture I am attaching from my repair manual what you are dealing with?
« Last Edit: April 23, 2023, 05:30:19 pm by Mike81K10 »
  • Keep em alive
« Reply #98 on: April 23, 2023, 05:31:07 pm »
The whole is where a cup that holds the assembly together bolts up. But you have a point, might be something that gets depressed there or somewhere else.
  • Keep em alive
« Reply #99 on: April 25, 2023, 11:20:52 am »
Just pulled the rubber boot at the fire wall, and the hole in the firewall was big enough to rotate the steering column and pull it out.
« Reply #100 on: April 25, 2023, 06:08:55 pm »
Why are you trying to take it off?
  • Keep em alive
« Reply #101 on: April 25, 2023, 06:20:00 pm »
The truck was a three speed on the column. Converting it to a floor shift. I purchased a used steering column that came out of a truck with a floor shift. Just looking to swap out the columns
  • Old Goof
« Reply #102 on: April 25, 2023, 07:30:29 pm »
You can swap the column without removing that arm, right, doesn't it come out through the firewall?
If you can't, torch it off.
  • Keep em alive
« Reply #103 on: April 25, 2023, 07:33:45 pm »
I am far from a body man... but I'm trying. Between multiple different shape wire wheels, sand paper, wire brushes, and acetone I think the firewall is clean. Hopefully it holds the paint I apply like the original did 49 years ago. My plan is rattle cans. Etching primer and rustoleum matte black. If I'm making a mistake please let me know...
  • Keep em alive
« Reply #104 on: April 25, 2023, 07:37:28 pm »
You can remove the column without ripping the shifter arms off. There is a cut out in the fire wall big enough to pull it out hole. Pretty much unbolt everything,  and twist 180 degree. The cutout is just big enough
