Author Topic: Driveshaft durability  (Read 17391 times)
Offline Swampyankee74
  • Keep em alive
« on: February 25, 2023, 09:57:32 am »
I have a 74 c1500 which originally came with a 250 6cl. I now have a 465 horse small block with a m21 tranny.  Is the stock driveshaft going to be able to handle that with occasional abuse? Or turn into a twizzler?
Offline JohnnyPopper
  • Old Goof
Re: Driveshaft durability
« Reply #1 on: February 25, 2023, 09:01:18 pm »
LOL Red twizzler
Pry a bd question.
1980 C-10 under construction
« Reply #2 on: February 26, 2023, 06:07:35 am »
Didn't you say you were lowering it? If so what method did you use to lower the rear? Check your operating angles, make sure appropriate clearance, slip and good u-joints. Download the angle meter app on your phone.
  • Keep em alive
« Reply #3 on: February 26, 2023, 07:55:03 am »
I did lower it 4 inches in the back by spring hanger and shackle method. I'll make sure all clearances, and that the slip yoke isnot to far into the tranny, and new u joints. Just checking to see if that old tube could take the beating.
