Body, Glass & Paint
Hood Hinge and Spring Replacement ???
Topic: Hood Hinge and Spring Replacement ??? (Read 6972 times)
Chevynut73
June 24, 2023, 11:24:26 am »
Well, my 50 year old hood hinges and springs are pretty weak it seems so i replace them with new ones and now they are sooo tight that i'm concerned i'm going to bent the hood while closing it.
Is this a common problem?
Other than oil them, what can i do to help loosen them up?
Thanks
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
JohnnyPopper
Old Goof
Re: Hood Hinge and Spring Replacement ???
June 24, 2023, 03:20:59 pm »
Only time and lubrication will allow it to wear in.
If you're in danger of it pancaking the hood, I would invest in some hood savers.
1980 C-10 under construction
June 24, 2023, 07:44:14 pm »
Put the OE springs back in
philo_beddoe
77 C-10
June 25, 2023, 03:57:35 pm »
Vice-grip garage explains it well. “Push in and down.”
Shifty
I bleed Bowtie red...
June 26, 2023, 11:03:05 am »
Quote from: VileZambonie on June 24, 2023, 07:44:14 pm
This....better then bending the hood, or cracking paint.
98 C2500 ext cab longbed
Chevynut73
June 28, 2023, 08:12:21 am »
Ok, great advice - thank y'all.
The original springs are too weak - but think i found a fix for this.
Lubed the poo out of them and got a friend to help me close the hood very slowly (needed 2 folks to close her without doing any damage). Kept the hood closed for several days and let the springs stay extended!
Opened it up last night and its getting better - now one person can close it
Shifty
June 28, 2023, 10:10:02 am »
Good deal!
Body, Glass & Paint
