Author Topic: Relocating Parking Brake Cables Because of Exhaust?  (Read 33409 times)
Offline devildogmech
« on: August 14, 2025, 01:38:51 pm »
Hey all,
So, I have a 1979 C-10, Bit Ten. Trying to finish up my LS Swap and I'm at the point where I can get the exhaust finished up.
The truck, of course, was originally a SBC 350, and the exhaust was in just a different place. My Exhaust runs just over or just under the parking brake cables and rods. I don't think 1/8" clearance is enough..... Have any of you relocated your Parking Brake gear to clear exhaust?
Thanks in advance,
Will in Chicago.
Be good, but not too good.
Re: Relocating Parking Brake Cables Because of Exhaust?
« Reply #1 on: August 14, 2025, 06:37:19 pm »
Yes. In fact the cable routing in 79 was pretty bad so modify it as you see fit as long as it works.
Offline Gwtt
« Reply #2 on: August 22, 2025, 06:58:06 pm »
I had the same issue. Order all the 81-87 short bed parking brake cables and it will route on the drivers side frame rail. Out of the way of exhaust. I did have to make a bracket but you could find it at a junk yard although it’s riveted on the frame.
« Last Edit: August 22, 2025, 07:09:16 pm by bd »
