Author Topic: Starter Dragging  (Read 35910 times)
Offline Chevynut73
Starter Dragging
« on: November 29, 2025, 12:22:49 pm »
The starter turns over good when engine is cold BUT after driving 20 - 30 minutes it drags bad and won't start until it cools down.
Do I just need a new starter?
If so, where would y'all get one?  Just local auto parts house?
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Offline Rapid Roy
  • Euless, Texas
Re: Starter Dragging
« Reply #1 on: November 29, 2025, 01:11:41 pm »
I had this a few years back. Replaced starter and still had dragging. Replaced cables and solved problem. Cables were probably original, no way of knowing. Be sure battery is good also. Recommend getting AC Delco starter if you can. I also got a starter heat shield wrap just in case it may need it.
« Last Edit: November 29, 2025, 01:14:30 pm by Rapid Roy »
Mopar by Birth
Chevy by Choice
« Reply #2 on: November 29, 2025, 01:58:06 pm »
What do you mean dragging?
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: December 01, 2025, 02:24:21 pm »
Sounds like sluggish performance
1980 C-10 under construction
Offline Chevynut73
« Reply #4 on: December 01, 2025, 03:40:19 pm »
Dragging = sounds like the battery is run down but it's not, turning over very slowly (only with operating temp motor).
Offline Chevynut73
« Reply #5 on: December 01, 2025, 03:42:33 pm »
Thank you - I can try that.
  • Old Goof
« Reply #6 on: December 01, 2025, 07:21:11 pm »
Electrons don't like heat
Offline zucchi
    • Driving my old car forever video channel
« Reply #7 on: December 09, 2025, 07:17:14 am »
As posted above…
Be sure to thoroughly clean BOTH positive and negative connections on each end of each battery cable.
Why pay some inept wrench turner to break something, then claim it was that way when I brought it in, when I can break it myself for free and learn something along the way.
  • Old Goof
« Reply #8 on: December 11, 2025, 11:42:28 pm »
Icing on the cake: use DeOxit on both ends... 8)
