Author Topic: Dash brake light  (Read 5891 times)
Offline MY1978
  • Just a girl and her truck since 1978
Dash brake light
« on: June 21, 2026, 12:58:50 pm »
Hello, I have a new issue.
My dash brake light is stuck on even while in drive.  I have depressed the emergency brake and released several times but it doesn't go out.  I have checked the fluid level and it is fine.  Every once in a GREAT while, it will go out.  Today I ran a couple of errands and drove for over an hour and the light stayed on.  Any suggestions/thoughts?
Online bd
Re: Dash brake light
« Reply #1 on: June 21, 2026, 03:08:18 pm »
Is there any pattern as to when the brake warning lamp extinguishes?  Unplug the tan/wht wire from the brake combination valve to see whether the brake warning lamp goes off and remains off.
Offline MY1978
« Reply #2 on: June 21, 2026, 03:48:58 pm »
No, no pattern.  I assume the brake combination valve is under the hood?  I will try that tomorrow.
**I found an explanation as to where it is.  I will try that tomorrow**
« Last Edit: June 21, 2026, 03:54:53 pm by MY1978 »
Online bd
« Reply #3 on: June 21, 2026, 04:20:11 pm »
The brake combination valve is a roughly 2.5" x 5" x 1" brass block that has 5 brake lines running to it and a single-pin switch that connects to the tan/wht wire for the brake warning lamp.
« Last Edit: June 21, 2026, 10:12:46 pm by bd »
Offline MY1978
« Reply #4 on: June 21, 2026, 04:33:11 pm »
Thank you
« Reply #5 on: June 23, 2026, 04:37:28 pm »
There is a connector for it near the steering box. Just unplug it there.
Offline MY1978
« Reply #6 on: June 23, 2026, 04:39:49 pm »
Thanks.  So I do not need to shimmy under the truck.  Nice.  I am so afraid I will break it when I unplug it because EVERYTHING is old on this truck.  Wish me luck.
« Reply #7 on: June 23, 2026, 04:50:18 pm »
See image
