Electrical
Dash brake light
Topic: Dash brake light (Read 5884 times)
MY1978
Just a girl and her truck since 1978
Dash brake light
June 21, 2026, 12:58:50 pm »
Hello, I have a new issue.
My dash brake light is stuck on even while in drive. I have depressed the emergency brake and released several times but it doesn't go out. I have checked the fluid level and it is fine. Every once in a GREAT while, it will go out. Today I ran a couple of errands and drove for over an hour and the light stayed on. Any suggestions/thoughts?
bd
Re: Dash brake light
June 21, 2026, 03:08:18 pm »
Is there any pattern as to when the brake warning lamp extinguishes? Unplug the tan/wht wire from the brake combination valve to see whether the brake warning lamp goes off and remains off.
MY1978
June 21, 2026, 03:48:58 pm »
No, no pattern. I assume the brake combination valve is under the hood? I will try that tomorrow.
**I found an explanation as to where it is. I will try that tomorrow**
Last Edit: June 21, 2026, 03:54:53 pm by MY1978
bd
June 21, 2026, 04:20:11 pm »
The brake combination valve is a roughly 2.5" x 5" x 1" brass block that has 5 brake lines running to it and a single-pin switch that connects to the tan/wht wire for the brake warning lamp.
Last Edit: June 21, 2026, 10:12:46 pm by bd
MY1978
June 21, 2026, 04:33:11 pm »
Thank you
June 23, 2026, 04:37:28 pm »
There is a connector for it near the steering box. Just unplug it there.
⌠ŻŻŻŻŻ' [☼===☼]
MY1978
June 23, 2026, 04:39:49 pm »
Thanks. So I do not need to shimmy under the truck. Nice. I am so afraid I will break it when I unplug it because EVERYTHING is old on this truck. Wish me luck.
June 23, 2026, 04:50:18 pm »
See image
⌠ŻŻŻŻŻ' [☼===☼]
Electrical
Dash brake light
