Author Topic: Steering shaft lower bushing/bearing assembly  (Read 32695 times)
Offline frotosride
    • WFO CONCEPTS
« on: June 23, 2026, 01:41:33 pm »
I did a quick search and didn't immediately see anything specific to this so here goes...
When installing the lower column steering bushing and bearing, is it best to; (1) do the white plastic bushing and then press the bearing in or (2) press the bearing into the bushing and then assemble to the the lower column shaft?
« Last Edit: June 23, 2026, 02:36:19 pm by frotosride »
Re: Steering shaft lower bushing/bearing assembly
« Reply #1 on: June 23, 2026, 04:38:30 pm »
As long as it's seated and the snap ring is in the grooves with the notch lined up you're golden.
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: June 24, 2026, 06:11:30 am »
Yes, the ultimate goal...
Having done this simple process now, the recommendation is to do them separate after cleaning up the shaft and removing any burs. It wouldn't be difficult to assemble them first but definitely annoying to try and slid them on the shaft and getting the bushing in the right slots without damaging it.
