Motor mount brackets wrong?
Topic: Motor mount brackets wrong? (Read 7853 times)
JaredD
June 27, 2026, 11:35:57 pm »
I am installing a sbc in a 83 C10 and I noticed the top clamshell tabs appear to not rest on the supports since the motor mount brackets flair at the top; does this look correct? On one side the tab is barely under the bracket but as you can see the other is within it. I bought the motor mount brackets off of eBay but I’m wondering if I got the wrong parts? See part number in pic below.
Last Edit: June 29, 2026, 10:11:29 am by Captkaos
Re: Motor mount brackets wrong?
June 28, 2026, 02:44:44 pm »
Well the mounts look odd... This is what you should be using
