Author Topic: Look what I ordered today!!  (Read 5818 times)
Offline xtreme80
« on: February 01, 2007, 07:30:00 pm »
www.jegs.com/webapp/wcs/s...9_-1_10763
I was originally going to build an engine, but realized I just don't have the time or the proper guaging equipment to build an engine like GM could.  Plus, this one has a warranty with it.
My work is also gonna let me borrow the cherry picker we have, so I can do this bad boy at home next weekend!
I'm really excited.  It's also getting some tires.  Check out my post in the tire section for info on that!
Offline 75 C20
Re: Look what I ordered today!!
« Reply #1 on: February 01, 2007, 07:55:00 pm »
thats sweet- did u git the complete on or more bare one- thats a good price either way
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline xtreme80
« Reply #2 on: February 01, 2007, 08:01:00 pm »
I got the long block, not the complete kit.  I already have an Edelbrock Performer intake manifold, and my carb is still workin great, plus I'm out of money.  My parents are already helping me a bunch with this, since I spun a bearing and have no transportation.
But it should still be nice and quick.
Offline xtreme80
« Reply #3 on: February 01, 2007, 08:02:00 pm »
Also, can anyone tell me more about the cam that's in this engine?
I really want it to have a nice lopey sound to it, since I'm running a fairly unrestricted exhaust, and I want to have a nice sound.  Will this give me that?
« Reply #4 on: February 01, 2007, 08:49:00 pm »
The valve lift has .450'' intake and .460'' exhaust lift with hydraulic flat tappets.
Very mild, not much larger than stock. At idle you'll have a little put put but nothing that you're lookin for for sound unfortunately
Offline xtreme80
« Reply #5 on: February 01, 2007, 08:59:00 pm »
That's too bad.  It's still gonna be a nice engine, I was just hoping for a meaner sound.
I thought about upgrading the cam, but the price would jump quite a bit, and if I did it myself, it would void my warranty with GM.  Can't do that.
Offline Tire Burner
« Reply #6 on: February 02, 2007, 01:22:00 pm »
If you want more lift, just put some Ratio Rockers on there. I got 1.6s on mine. That would probably bring your lift up to 490ish. New Rocker sets like that aren't that expensive either and you would be upgrading to Rollers most likely.
lift
« Reply #7 on: February 02, 2007, 05:30:00 pm »
If the valve lift is .450/.460 with a 1.5 rocker ratio then your lobe lift is .300/.307
The duration on the cam is 222°
If you went with a 1.6 ratio the valve lift would be .480/.491
Most cams with that much lift have a duration around 290° which you will not have.
So changing the rocker ratio will just essentially give you worse fuel mileage. Just leave your cam alone then and when the warranty is up or close to it do some tweakin :smokin
*edit forgot decimal point
Edited by: VileZambonie  at: 2/2/07 5:32 pm
