Author Topic: just a question about motors  (Read 4722 times)
Offline magnum59
« on: April 22, 2007, 02:50:57 pm »
We will be removing a 4.3 from a 1985 chevy c10 custom pickup and would  really like to up grade to a 305- my question is -is this possible with out changing everything in the drivetrain?The 4.3 is tost any way and we are looking at a crate  305 for about the same price as the 4.3.
 thanks
magnum
Re: just a question about motors
« Reply #1 on: April 22, 2007, 09:11:52 pm »
You'll have to change a few things...but nothing drivetrain related. I have a 305 for sale if you are anywhere local....
« Reply #2 on: April 22, 2007, 09:14:36 pm »
Bigger radiator, clutch if its a standard, exhaust manifolds, etc.
Offline red4wd
« Reply #3 on: April 22, 2007, 09:44:38 pm »
Distributor, intake, exhaust manifolds are the main things if you are doing a crate motor.  I am sure you would have to move the mounts on the frame as well.  You might have to have a fan shroud to go with the larger radiator that blazin mentioned.
123pugsy
  • Guest
« Reply #4 on: April 23, 2007, 11:41:41 am »
If you don't have A/C ,the small rad may be sufficient. Had a small rad with a 305 and it kept cool OK.That was in an 88.
