Author Topic: TPI onto 86 Block  (Read 187642 times)
Offline 123 pugsy
Re: TPI onto 86 Block
« Reply #60 on: July 21, 2007, 05:17:26 am »
Well there's lotsa grey wires and schematics aren't listed by where they're routed so you'll have to trace where the other end goes in order to follow it on a schematic.
Thanks again! Another brain fart. I traced it back to B11. It looks like a signal for the speedo.
If it's any consolation, I had to repin a 92 z28 motors wiring harness to match my brothers 88 IROC body....that took a month! Anywho...the posted pictures are the c207 connectors. They control a TON of stuff! If you can figure out what year you nead, you can search the www.thirdgen.org forums for a "c207 diagram", or google search the same. You can also try this one:
Thanks 77c15
I found the c207 connector on the diagram Vile posted. What makes it difficult to spot is it shows just 2 of the connections (D and P )from the total 15 in the connector.
Thanks again guys. My wiring is complete!
BTW, is the speedo on the Firebird electronic as in no speedo cable?
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #61 on: July 21, 2007, 05:26:28 am »
Vehicle Speed Sensor. Just screw in and done. ( I hope )
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #62 on: July 21, 2007, 05:30:13 am »
Made up a bracket Friday morning at work for the fuel filter. I will bolt this to the frame. It secures with 2 stainless steel hose clamps for easy removal.
Pugsy
76 C10 LWB
TPI 350
Online VileZambonie
« Reply #63 on: July 21, 2007, 08:58:24 am »
Beautiful! Very nice fuel filter mount.
B9 and B10 are going to connect to your VSS.
B11 Won't be used on your truck since your speedo is cable driven.
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #64 on: July 21, 2007, 09:41:13 am »
Where did you get that part? My brothers IROC is cable speedo, but the 92z tranny is speed sensor. That would be a HUGE help to get his speedo working again. Please let me know the part number and where to get it. Thanks!
Offline 123 pugsy
« Reply #65 on: July 21, 2007, 02:33:53 pm »
I ordered a VSS from Stealth Conversions Part #4PAC
https://shell7.tdl.com/~jags/SpeedSensors_Order.html
« Last Edit: July 21, 2007, 04:35:34 pm by 123 pugsy »
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #66 on: July 24, 2007, 08:20:02 pm »
Made up a few pieces at work Monday morning for the air filter box. I'm planning on running 4" duct from the rad support ,into the filter box and into the throttle body. I hope I can do this without relocating the alternator or without removing the stock fan and shroud.
Pugsy
76 C10 LWB
TPI 350
« Reply #67 on: July 24, 2007, 11:56:33 pm »
SWEET!  What do you normally do at work? :D
Offline 123 pugsy
« Reply #68 on: July 25, 2007, 05:23:00 am »
Thanks Vile.
Thanks Chris.
I am a stainless steel sheet metal fabricator for restaurant equipment. I have a small shop in Toronto with 10 employees.We also do mirror finish s/s truck parts for a trucking company on occasion.That's why I happen to have stock on the shiny stuff.  ;)
« Last Edit: July 25, 2007, 05:26:51 am by 123 pugsy »
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #69 on: July 25, 2007, 05:34:37 am »
A little off the TPI but I thought I'd throw it in. I picked up a metal shrinker and stretcher on the weekend and had an order come in yesterday that actually needed these tools. Just thought I'd let you see what they are capable of. This is 20 ga s/s:
I see some great potential there for fabbing up parts for bodywork in the future.
Pugsy
76 C10 LWB
TPI 350
Online VileZambonie
« Reply #70 on: July 25, 2007, 12:44:33 pm »
dang Pugsy, you should fab something real nice up to sell specific for our trucks! Maybe a nice stainless washer bottle or coolant can or wiper motor cover...lol boy if I had access to that stuff I'd be all over it!
« Reply #71 on: July 25, 2007, 05:22:17 pm »
That is cool.  My buddy has started playing with stainless lately.  I am trying to get him to make some parts for our trucks.  He is working on some right now, and I am trying to get more from him.
Offline 123 pugsy
« Reply #72 on: July 25, 2007, 07:06:10 pm »
Here's a nice piece that brigtens up the top of the rad support.
Before:
After:
Here's an overflow tank:
I have to cut it down as its in the way of the intake air,
It uses the stock plastic filler cap.
« Last Edit: July 25, 2007, 07:11:05 pm by 123 pugsy »
Pugsy
76 C10 LWB
TPI 350
Offline Toolmaster
« Reply #73 on: July 25, 2007, 09:38:28 pm »
Sharp !  :o 8)
« Last Edit: July 29, 2007, 02:30:07 pm by Toolmaster »
Offline 78BBSTEPSIDE
« Reply #74 on: July 26, 2007, 10:22:26 pm »
Some beautiful work! I bet you could fabricate a gas tank that would put Rock Valley to shame, and they build one heck of a gas tank!
