73-87 Chevy & GMC Trucks
85 Blazer electrical haywire
Topic: 85 Blazer electrical haywire (Read 4095 times)
dwill223
New Users
June 21, 2007, 10:38:15 pm »
I have a 85 K-5 Blazer and the other night i pulled out of the parking lot and when i hit the gas the headlights, taillights, dashlights and lighter went out. The alternator was pushing around 14 amps before this happened now it pushes 12. I have checked every ground I can find and did the best i could at the wiring but it seems to be something wrong in the fuse block. I pulled the block apart to check the wires and when i put it back together i didn't start. pulled apart again and it started when put together. I have even checked the wires themselves looking for melting point or something. Am I missing something or is it time for a $530.00 painless pill. Any help would be greatly appreciated!
Re: 85 Blazer electrical haywire
June 22, 2007, 05:16:29 am »
Well I would check how you put back together the fuse block and make sure it went together 100%
Check your fusible links at the junction block on the firewall and down near the starter
dwill223
New Users
June 22, 2007, 12:09:29 pm »
Thanks, I'll check those and see if that helps.
