Author Topic: My 1980 Chevy C10 Restomod  (Read 675764 times)
Offline eventhorizon66
Re: My 1980 Chevy C10 Restomod
« Reply #450 on: April 15, 2010, 07:01:27 pm »
Thanks for the eye candy.  That engine is like a diamond.
What kind of an accessory drive will you be running?  March Ultra?
'85 C10 SWB 350 700R4 TKO600
Offline 80stepsideguy
« Reply #451 on: April 15, 2010, 09:39:35 pm »
Yes by march performance serpantine setup.Although i got a keyway power steering pump pulley i am going to look for a keyway pump instead of a press on fit one as we have on our trucks..
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline 1983stepside
« Reply #452 on: April 17, 2010, 12:14:30 pm »
the truck is looking good man i saw your looking for a new harness, i got one for my stepside from a company called ez wireing, the fuse block is all pre wired, and the wires are labled where they go every 5 inches it cost after tax and shiping 280, if i remember corectly they have a web site go check them out, there the same quality as the bigger named harnesses i think but a lot cheaper, just given you another idea where you can get a harness if chris doesnt sell them 8)
« Reply #453 on: April 17, 2010, 01:05:23 pm »
I appreciate the heads up man.
Chris i am going to go with the 1 1983 has provided me.Although chris im sure is busy as heck like vile here on their rigs i think i will go with this 1 you named.I am trying man with the funds i got i am limited now to so much.I am doing a rear disc conversion kit from a 1995 impala SS .Only downfall is there is no E brake.But it should be ok..But im hopingto have almost all but the interior done by winter...2 major components im looking at are the radiator and the brake booster which will be close to 1,000.00 So right now i`m doing lil by little...
thanks
pat
« Reply #454 on: April 18, 2010, 09:48:57 pm »
no problem man im glad i was able to help someone finally on this site for once, i havent installed my harness yet for as im no where ready for it, i jumped the gun a little on buying it but i guess at least now when im ready ill have it, but it comes with all the conectors for the headlights and and its wired for a gm column, the only thing is if your planning on running stock gauges youll have to figure a way to get the new harness to work on the stock gauges let me know how it goes when you get it and install it 8)
« Reply #455 on: April 23, 2010, 05:31:15 pm »
Started putting some more powder coated parts on today, and now i am considering taking the rearend out  and going to have my spare one torn apart and blasted and powdercoated and new gears and a posi put in it and put my old rearend aside.Im going to be putting discs in the rear so i think this is going to be my next project....
Pics to come ..
thanks
pat
Offline hotrod24
« Reply #456 on: April 26, 2010, 07:03:55 pm »
Cool you are really going all the way man, keep it up
1978 pontiac grand prix...
Offline Lucky73
« Reply #457 on: April 27, 2010, 11:26:09 am »
one nice truck.you definitely have a labor of love for these trucks,as most of us do :)
73 Chevy C10
73 GMC K20
93 Chevy S-10
« Reply #458 on: April 27, 2010, 11:49:44 am »
Thanks lucky,
it is a labor of love and a definate wallett drainer lol... I figured i got the spare rearend and the rest of the underside was done nicely i may as well go the extra mile and do it to the rearend.Funny thing is i just had the drums cut and all new brakes and cables and hardware put into the 1 i just redid.. But i think since im running 20s on the rear it would look better all nice n powdercoated and shiny..So this friday i`m sending the housing to get powdercoated and then get it back and save up for the internals like a set of gears and a locker and  go from there...
thanks
pat
Re: 1980 Chevy C10 Restomod Project
« Reply #459 on: May 15, 2010, 01:33:20 am »
Ok well i got some more eye candy rearend is back from powdercoat, sorry for the blurry pic, bed is comming along.I had my folks buy me the wood kit so i stained it w/ 3 coats of BEHR redwood stain and 3 heavy coats of polycrylic clearcoat.I need to add the metal braces underneath and then cut the hole for the gas door..But its comming along very slowly but hoping to get the parts for the rearend soon.I need to get my backside in high gear n get this thing going a lil faster then its currently going....
thanks
pat
Offline Layne
« Reply #460 on: May 15, 2010, 04:23:48 am »
That looks killer man! Can't wait to see it on the truck
« Reply #461 on: May 15, 2010, 02:00:03 pm »
You didnt cut the fuel hole BEFORE your painted? I dont have a hole, I have a fuel door in my fender...so maybe Im not sure what your talking about.
« Reply #462 on: May 15, 2010, 05:24:24 pm »
I think he's putting the hole in the floor. The bed looks molta bella! Keep up the good work man it's really going to be a gorgeous truck!
« Reply #463 on: May 15, 2010, 06:34:34 pm »
Thanks guys
Beastie,,, vile is correct i am putting the fuel door in the rear  of the bed.There is going to be a polished gas door .Thanks vile i hope it will be a sweet truck , it sure is taking alot out of me but it will be well worth it..
thanks
pat
« Last Edit: May 17, 2010, 02:29:20 am by 80stepsideguy »
« Reply #464 on: May 15, 2010, 07:09:32 pm »
OK cool. I probably missed it in a earlier post. Looks good!
