Author Topic: 73-87chevytrucks.com - Jimmy Project  (Read 112400 times)
Re: 73-87chevytrucks.com - Jimmy Project
« Reply #105 on: July 30, 2008, 07:50:02 pm »
1978 GMC Jimmy 2WD Crossmember.
Offline eventhorizon66
« Reply #106 on: July 30, 2008, 08:40:37 pm »
That's an odd choice.  How did you ever get it to fit?
'85 C10 SWB 350 700R4 TKO600
« Reply #107 on: July 30, 2008, 10:30:20 pm »
Well, it is IN a 1978 GMC Jimmy 2WD, so it fit fine since it came in there.
« Reply #108 on: July 30, 2008, 10:36:19 pm »
Maybe an LOL or :D would have been appropriate at the end of my last post.  Sarcasm doesn't translate well in type.
« Reply #109 on: October 07, 2008, 08:26:46 am »
Little update:
Friday, Oct 3,2008: I cut on both Y-pipes that I recieved from Thorley to make one that would fit the truck.  Got 2 of the pipes close
Saturday, Oct 4,2008: After some serious hacking and cutting I got the pipes cut down so they would be close enough to put together
Sunday, Oct 5,2008: Toolmaster came over and got them tacked up and weled up the pipes for me.  Now I just need to send them off to get coated.  No pics as my camara has screwed up on me...
This is where I started (don't have pics of the after fab)
« Last Edit: November 19, 2008, 04:58:50 pm by Captkaos »
« Reply #110 on: October 07, 2008, 10:37:49 am »
Little update:
Makes me glad I ordered the straight-back long tubes and had a y-pipe fab'd.  How bad was it?  Was it the trans crossmember or the trans itself in the way?
« Reply #111 on: October 07, 2008, 11:19:56 am »
The first pipe I got was just WRONG.  If it had the 3" collector or even a 2.5" instead of a 2.25" on it and wasn't welded so the outlet was pointing towards the framerail, I could have used it.  The second was touching the torque converter WITH pressure, and on the outlet it was pressed up against the floorpan.
« Reply #112 on: October 07, 2008, 05:13:35 pm »
Wow.  I hope you gave Thorley an ear-full about this.
« Reply #113 on: October 07, 2008, 06:27:04 pm »
Yeah, I was not happy.  On the plus side they are doing me right.
« Reply #114 on: November 19, 2008, 04:57:58 pm »
Friday, Oct 31st, 2008: I received they Y-pipe back from Doug Thorley after It was ceramic coated.
This is what I got coated:
Saturday, Nov 1st, 2008: I got it installed!
This is it installed:
This is the floor/crossmember clearance:
« Reply #115 on: November 19, 2008, 05:03:46 pm »
Cool.  Glad to see you got the headers all sorted out.  I guess the next step is turbo mockup?
« Last Edit: November 20, 2008, 04:41:39 pm by eventhorizon66 »
« Reply #116 on: November 19, 2008, 05:20:03 pm »
Yep!  I should be ordering the pipe soon.
Offline JJSZABO
« Reply #117 on: November 20, 2008, 07:17:28 am »
Wow Chris, that looks much better.
Please post PICS of the turbo install.  I am interested in how it goes together.
My first "brand new" car was turbocharged.  Chevy Sprint 3 cylinder, 1 litre built by Suzuki.
A really fun car to drive.  43mpg with using the turbo.
Jeff
86 Chevy C-10
350, TH400
« Reply #118 on: November 20, 2008, 04:03:00 pm »
It will all be documented right here for all to see...
I love Turbo's
Offline bigkountry
« Reply #119 on: November 22, 2008, 09:14:58 pm »
You are using the STS rear mount correct?
