Author Topic: Needing a bit of help with this:  (Read 6001 times)
Offline Mr79C10
  • My 79 C-10 Project
    • My 79 C10 Project
« on: August 05, 2007, 12:46:06 pm »
In floor repair this is what I have to fix.
My questions Do i need to replace both rockers,inner,outer?
Or can I just give em a good solid cleaning and tac weld some metal, The inner rockers seam to be ok, its just where the welds were and the floor has been eatin.
*House of Friends
Re: Needing a bit of help with this:
« Reply #1 on: August 05, 2007, 04:30:47 pm »
If you want the truck to last at all cut out ALL rust/rot and weld in new metal. When you weld in the new metal prep and corrosion protection is key.
« Reply #2 on: August 06, 2007, 12:46:59 am »
There are no welds in the area of the rot in the first picture. The inner rocker is part of the floor when the cabs are built at the factory. Pull the gasket out of the way and the mat etc. then you can make an accurate evaluation of the rust. If its not bad you could make a patch for that area. I have patched the same area on many trucks. If you are looking for long life I would say replace a larger section. If you are looking for a few years then patch it.
Offline Mr79C10
    • My 79 C10 Project
« Reply #3 on: August 12, 2007, 05:42:38 am »
I could get a floor pan and just cut off what I need and weld in place, I don't have to cut the whole pan?
*House of Friends
« Reply #4 on: August 12, 2007, 08:30:19 am »
In theory yes you could cut down a pre mad patch, but I have never seen a floor patch that includes that area. The biggest ones I have seen only go back to right before the front seat bolt holes.
« Reply #5 on: August 12, 2007, 08:31:36 am »
Yes, you only need to cut out what is really rusty and weld in place from a donor pan.
