Body, Glass & Paint
rocker panels/cab corners
Topic: rocker panels/cab corners (Read 4938 times)
the_legend_1981
August 19, 2007, 02:50:28 pm »
what do you guys think about using filler to patch the rockers and cab corners. there are just a few small holes in them. what if i paint the back of them and then patch them and finally prime them?
Re: rocker panels/cab corners
August 19, 2007, 08:46:40 pm »
Fine if you want it to last a year or so. Otherwise weld in new metal.
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
August 20, 2007, 05:37:21 am »
If you paint them first then put filler on / in them they probably wont last three months. Filler is designed to stick to bare metal that had been ground to create a mechanical bond. If you sand blast them and use short strand fiber glass filler you could get a year or maybe a little more from them. I wouldn't waste money on expensive primers / paint etc. if you go this route. They are not going to slow the rust down as it will be buried under the filler.
SUX2BU99
August 22, 2007, 02:20:01 pm »
If you do just a filler patch and paint, make sure to remove all of the rust that the filler and paint will sit on. Whether it's surface rust or total rot, grind it down to fresh metal and then go from there.
Body, Glass & Paint
