73-87 Chevy & GMC Trucks
Newbie help???
Topic: Newbie help??? (Read 6848 times)
Rockin77
Newbie help???
September 01, 2007, 11:11:07 pm »
I have a Gmc 3/4 ton HIght sierra and i was wondering on the passanger side exaust manifold there is a small valve or switch. What is that for??
Last Edit: September 03, 2007, 10:25:15 pm by Rockin77
1977 GMC High Sierra 25
Re: Newbie Question???
September 02, 2007, 01:05:16 am »
Can you post a pic of exactly which part you mean? There's a big difference between a switch and a valve. Basically here are some of the things you might find on your exhaust manifold:
Heat riser
Stove Pipe
O2 sensor
AIR components
Rockin77
September 03, 2007, 09:44:25 pm »
Here is the switch sorry for the bad pix they were takin with a camera phone
and this ring around my drive shaft were does it go or can i cut it off??
Re: Newbie help???
September 04, 2007, 04:11:13 pm »
I'm not seeing a switch in that picture although I am getting a headache trying to figure it out
Are you talking about the heat riser valve? The lever between the exhaust manifold and the exhaust pipe.
That bushing goes inside your slip yoke.
Re: Newbie help???
September 04, 2007, 05:39:33 pm »
I agree, I can't tell from the pic. It is probably the heat riser though as VILE indicated...
Rockin77
Re: Newbie help???
September 05, 2007, 10:07:07 pm »
Ya it must be the heat valve. Thanx for the help. Do you have a pic of where the bushing goes because i have no idea. thank you
Toolmaster
Re: Newbie help???
September 06, 2007, 10:59:05 am »
It looks like the dust seal that should be inside the dust cover on the end of the yoke. Prevents dust from entering the splines of the yoke. Try removing the cover (should un-screw from the yoke) it will have very fine threads. Someone could have removed the yoke and not known where to place the seal. The seal will be a felt type but over the years they get kinda hard with all the crap that builds up on them.
If that is what it is, you will have to un-spline the yoke from the shaft, remove the cover and place the seal inside the cover. Then make sure to keep your d/shaft in time and reinstall.
The first photo is the heat riser valve. If you look at the photo up-side down you can tell what it is.
Last Edit: September 06, 2007, 11:01:15 am by Toolmaster
Hang him !!! (Judge Roy Bean) Looters will be shot on site !!!
DnStClr
Re: Newbie help???
September 08, 2007, 03:26:57 pm »
Nuts! I turned my laptop upside down and one of my
shift
keys fell off!
Don
87 Chevy Silverado
Rockin77
Re: Newbie help???
September 12, 2007, 11:52:56 am »
that ring om my drive shaft is metal
77c15
combustion=suck, squeeze, bang, blow
Re: Newbie help???
September 12, 2007, 09:51:34 pm »
That ring on your driveshaft is part of the carrier bearing/2 piece driveshaft assembly.
ccz145a
Re: Newbie help???
September 13, 2007, 09:22:10 am »
Yep, but where does it go? I just replaced carrier bearing about a month ago. The box had one of these in it, but nothing like it was installed on my truck, so I left it off.
77c15
Re: Newbie help???
September 14, 2007, 08:02:30 am »
There's a cup on the front part of the rear shaft. You should be able to remove it with a good pair of pliers. The seal goes inside there. Then retighten, grease, and reinstall.
Newbie help???
