Author Topic: coolant overflow bottle  (Read 6955 times)
Offline 79GMClowboy
« on: September 11, 2007, 10:22:09 am »
I did the 90 blazer front end job on my 79...Just wondering what coolant bottle do I use? it has the 90 model inner fenders...Reason I ask is I have tried to buy this on ebay but they are never listed as 88-91 blazer or suburban coolant bottles...Can the one for a truck those years work? they are listed. I need a new one...I know this is a stupid question.
Offline FlatBlack77
Re: coolant overflow bottle
« Reply #1 on: September 11, 2007, 03:04:44 pm »
just run the over flow hose into an old oil bottle or something botled to the inside of the fender.
that=save$$
« Reply #2 on: September 11, 2007, 03:27:57 pm »
Its actually not an overflow bottle it's an expansion tank. When the cooling system heats up the radiator cap allows a small amount of coolant to enter the expansion tank. As it cools the radiator cap allows the coolant to be drawn back into the radiator. So an expansion tank should be able to hold a reserve of at least a pint and be able to catch ideally 2 quarts. So if you make your own don't make it too small.
Offline big lefty
« Reply #3 on: September 11, 2007, 09:47:26 pm »
You should be able to use anything from 85 to 87 if you have the new 88 to 91 inner fender. You can buy them from   or from ebay, but   has them for about thirty bucks.
1984 CHEVY 4X4  LOVE BOWTIE'S
« Reply #4 on: September 11, 2007, 11:15:38 pm »
88-98 truck pieces won't work.  You need something from either the 88-91 R/V or you can try one from the 81-87.  I can't remember if they changed those.
Offline 79GMClowboy
« Reply #5 on: September 19, 2007, 12:51:16 pm »
thanks capt..I got a cheap autozone bottle on it now....its gotta go...a new correct bottle is what I'm looking for...I called   and they said they were'nt sure what would fit....must of been because it was a female..... ;D
« Reply #6 on: September 19, 2007, 01:26:52 pm »
  isn't going to be able to help you regardless of who you talk to.
If you have the 89-91 R/V frontend, you need the same year tank.  Have you called the dealership and asked for one for a 91 Suburban/Blazer?  They MIGHT have it.
