73-87 Chevy & GMC Trucks
14Bolt Pinion Seal?
Topic: 14Bolt Pinion Seal? (Read 5391 times)
BigTree
14Bolt Pinion Seal?
September 27, 2007, 12:08:56 am »
Hey guys. Has anyone done a pinion seal on a 14B Full floater? The books are pretty vague... Any advice?
Thanks a ton.
Trevor
Re: 14Bolt Pinion Seal?
September 27, 2007, 01:18:11 pm »
yes, index the pinion nut, flange, and shaft before removing it so the nut isn't overtightened.
BigTree
September 27, 2007, 01:49:14 pm »
okie dokie. So mark where everything lines up, Impact the nut off, bang flange off, pop old seal out, that insert new one, and tighten till marks line up?
DirtyLittleSecret
September 27, 2007, 05:48:54 pm »
yup
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
BigTree
September 27, 2007, 10:46:42 pm »
Thanks a ton guys! Your awesome.
DirtyLittleSecret
September 28, 2007, 02:18:19 am »
Oh, and almost forgot that you might find that a strategic curse will help take the nut off. Usually works for me.
14Bolt Pinion Seal?
