Author Topic: Quick Inner Fender Question  (Read 6260 times)
Offline JJSZABO
« on: October 19, 2007, 07:01:01 am »
Do I need to seam seal between the inner fender and the outer fender when I put them together?  If not, will it help to do it or will it hold in the moisture?
Thanks in advance,
Jeff
Jeff
86 Chevy C-10
350, TH400
Offline ccz145a
Re: Quick Inner Fender Question
« Reply #1 on: October 19, 2007, 08:17:33 am »
Assuming we are talking about the front fenders... There was nothing in this joint from the factory. I just took apart my very rusty front end and nothing in this location was damaged exept the j-nuts.
Just bolt together and go.
Offline JJSZABO
« Reply #2 on: October 19, 2007, 08:34:10 am »
Thanks ccz145a  :)
That's what I found also when I took mine apart.  Was wondering if it would hurt putting seam sealer in there to keep the rust from reforming.
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: October 19, 2007, 09:18:43 am »
seam sealer won't stop rust. Don't seam seal them.
Offline JJSZABO
« Reply #4 on: October 19, 2007, 09:57:49 am »
Gotcha ;)  Thanks ;D
Jeff
Jeff
86 Chevy C-10
350, TH400
Offline okuma
« Reply #5 on: October 19, 2007, 10:04:47 am »
if you seam seal it you will seal-in
moisture and it will be worst!  ;)
« Reply #6 on: October 19, 2007, 10:59:47 am »
I always make sure there is a good coat of rust inhibitive self etching primer and paint on both surfaces before they go together.
Offline JJSZABO
« Reply #7 on: October 19, 2007, 01:07:15 pm »
Thanks guys!!!!
Jeff
86 Chevy C-10
350, TH400
