Body, Glass & Paint
Quick Inner Fender Question
Topic: Quick Inner Fender Question (Read 6256 times)
JJSZABO
October 19, 2007, 07:01:01 am »
Do I need to seam seal between the inner fender and the outer fender when I put them together? If not, will it help to do it or will it hold in the moisture?
Thanks in advance,
Jeff
Jeff
86 Chevy C-10
350, TH400
ccz145a
Re: Quick Inner Fender Question
October 19, 2007, 08:17:33 am »
Assuming we are talking about the front fenders... There was nothing in this joint from the factory. I just took apart my very rusty front end and nothing in this location was damaged exept the j-nuts.
Just bolt together and go.
JJSZABO
October 19, 2007, 08:34:10 am »
Thanks ccz145a
That's what I found also when I took mine apart. Was wondering if it would hurt putting seam sealer in there to keep the rust from reforming.
Jeff
86 Chevy C-10
350, TH400
October 19, 2007, 09:18:43 am »
seam sealer won't stop rust. Don't seam seal them.
⌠ŻŻŻŻŻ' [☼===☼]
JJSZABO
October 19, 2007, 09:57:49 am »
Gotcha
Thanks
Jeff
Jeff
86 Chevy C-10
350, TH400
okuma
October 19, 2007, 10:04:47 am »
if you seam seal it you will seal-in
moisture and it will be worst!
Blazin
Blazin new trails!
October 19, 2007, 10:59:47 am »
I always make sure there is a good coat of rust inhibitive self etching primer and paint on both surfaces before they go together.
JJSZABO
October 19, 2007, 01:07:15 pm »
Thanks guys!!!!
Jeff
86 Chevy C-10
350, TH400
Body, Glass & Paint
