Author Topic: STUCK DOOR "FROZEN"  (Read 13459 times)
Re: STUCK DOOR "FROZEN"
« Reply #15 on: October 24, 2007, 08:57:23 am »
I think we were trying to get the lock released by leaving the cylinder in and twisting it while pushing the button.  Since you removed it that is going to be harder as you will need 2 people now.
Offline Bitzer!
  • Smiles per gallon
« Reply #16 on: October 24, 2007, 04:09:39 pm »
can you get any heat to the bit the rods stuck in? gently warm outside so it expands that tiny bit?
1979 GMC CrewCab  C20 1t
Offline okuma
« Reply #17 on: October 24, 2007, 07:08:41 pm »
capt, I am not worried about the lock cylinder. i am worried that the whole door will not open' nor the lock rod that goes up on the door panel will move at all.
« Reply #18 on: October 25, 2007, 12:17:31 am »
I understand, but you can't push the button and pull the rod if they are blocking each other without someone on the inside and outside.  (unless the inside handle will unbind it)
« Reply #19 on: October 25, 2007, 09:58:32 am »
You need to actuate both the outside and inside release levers a few times. Then try turning the lock cylinder. A lot of the older ones would stick so you couldn't unlock it if you didn't.
