Author Topic: STUCK DOOR "FROZEN"  (Read 13457 times)
Offline okuma
STUCK DOOR "FROZEN"
« on: October 20, 2007, 10:05:14 am »
CAN SOMEBODY HELP ME HOW TO OPEN THE PASSANGER DOOR. THE TRUCK HAS BEEN SITTING ON THE GARAGE FOR SOME TIME NOW AND MY DOOR WILL NOT OPEN.
I have the door panel removed an all the hinges are connected. i press and/or pull the handles, i see the mechanism move but no luck....... I tried to pull up and down on the lock rod with some pliers and this will not move!
does anybody gone through this , i need help!
Offline GMCTed
Re: STUCK DOOR "FROZEN"
« Reply #1 on: October 20, 2007, 12:22:24 pm »
do you have the stock door handles on the truck? when i restored my suburban i bought new outer handles from   and three of the four doors would not open due to a little extra piece of metal (a manufacturing defect) on the inside of the mechanism that contacted the inside of the door and it stopped it from fully depressing the button and not allowing the door to open.
i just took them off and used a cutoff wheel to trim them.  i hope this helps....it took me a while to figure out what the problem was and it drove me crazy. ???
« Reply #2 on: October 20, 2007, 12:25:54 pm »
Is it the lock that is keeping it from working or the handle linkage?  you should be able to pull up on the lock lever with your hand to unlock it.  Is the latch unlatching at all, if so, try lifting on the door when you unlock it.
« Reply #3 on: October 20, 2007, 04:57:07 pm »
does the door lock cylinder turn with the key?
Offline okuma
« Reply #4 on: October 20, 2007, 10:41:07 pm »
THE DOOR LOCK ROD WILL NOT MOVE AT ALL! >:(
it was working properly all this time but i don't know why it is not opening now......
luckily i do not have the door panels installed yet!
I can see whats not moving, in my case the door lock rod even when pulled or pushed with pliers.....
Offline Mr79C10
  • My 79 C-10 Project
    • My 79 C10 Project
« Reply #5 on: October 21, 2007, 06:42:24 am »
PB blaster sounds likeit might be your best friend, spray the mechanism well, and then have a go at it.
*House of Friends
« Reply #6 on: October 21, 2007, 11:08:32 am »
Is there anything binding on the latch/lock?
Offline 78BBSTEPSIDE
« Reply #7 on: October 21, 2007, 12:07:32 pm »
Do you have the weather stripping installed? Did the door close past the normal position, past the two clicks of the latch mechanism due to no weather stripping. I have had this happen several times and it is a real bear to get the latch to release. Hard telling, but just a thought.
Offline okuma
« Reply #8 on: October 21, 2007, 10:41:13 pm »
I HAVE THE WEATHER SEALS INSTALLED<NEW> AND THE DOORS WOULD CLOSE VERY SMOOTHLY.MY DOORS WOULD NEVER BE SLAMMED SHUT I WOULD ONLY PRESS ON THEM TO CLOSE THEM.
WHEN I PRESS THE HANDLE BUTTON I SEE THE MECHANISM MOVE BUT WILL NOT OPEN.  IT SEEM TO BE ON THE LOCKED POSITION. THE ROD PRESSED DOWN BUT WILL NOT MOVE AT ALL.I HAVE HAD IT SOAKIN WITH PENETRANT 1-2 DAYS.... YET NO LUCK!  >:(   is there a  methood i can do---- remove something that will help me open it?
« Reply #9 on: October 22, 2007, 11:10:07 am »
What do you see when you turn the lock cylinder?
« Reply #10 on: October 22, 2007, 03:29:33 pm »
operate the handle a few times from the inside and then from the outside. Then try to turn the door lock cylinder with the key.
Offline v_dub_ya
« Reply #11 on: October 23, 2007, 12:13:18 pm »
Did you get the door open?
We had this happen with one of our work trucks, the lock cylinder was our problem.
Offline okuma
« Reply #12 on: October 23, 2007, 06:06:35 pm »
I HAVE REMOVED THE LOCK CYLINDERS COMPLETLY. AND THE DORR IS STILL THE SAME NO CHANGE AT ALL.  ---- PUSH LOCK ROD WILL NOT MOVE UP OR DOWN. :-\
« Reply #13 on: October 23, 2007, 09:23:08 pm »
Your caps lock key is stuck on too. Maybe that's the whole problem
Offline okuma
« Reply #14 on: October 23, 2007, 09:49:24 pm »
ok, thanx ville! ;)  but "i dought that will solve my problem"
