The Highs (Raising/Lifts)
Lift Kits and Brake Lines?
Topic: Lift Kits and Brake Lines? (Read 7570 times)
85MudMonster
October 25, 2007, 05:43:35 am »
I'm going to be putting a 6" suspension lift on my 85 K10 and I read in another tread about the brake lines needing to be lengthened. How is that done, and what do I need, cause the truck definitely needs to have working brakes on it. Any help/suggestions/tips?
Dan
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Re: Lift Kits and Brake Lines?
October 25, 2007, 09:13:39 am »
You don't actually "lengthen" the brakes, you purchase newer lines that are longer.
October 25, 2007, 10:02:06 am »
Just use drop brackets and lower the brake lines near where your flexible hoses are.
85MudMonster
October 25, 2007, 02:58:25 pm »
will the drop bracket cause anything to rub? I don't want them to be in the way of anything....
Dan
DirtyLittleSecret
October 29, 2007, 12:22:44 pm »
Pro Comp makes a very affordable stainless steel braided kit of extended brake lines (about $100). I had to do this for my 4" lift, and is a definite need on a 6". A VERY simple job, but time/knuckle consuming! Also allows you a really good brake system flush (probably desperately needed).
There shouldnt be any rubbing, and its a really easy job. Do make sure that you get EVERYTHING soaked in PB Blaster the day prior to get it so that it will all break loose! Wear latex gloves, and have at it!
78 K20: fresh 350, SM465, NP205, 4" Pro Comp, & working hard!
65 Jeep J300: 13.5:1 383, TH400, NP205, mostly NOS.
88 Toylet LandCruiser FJ62: LT1, 4L60e, 3" OME, Aussies.
06 VW TDi: DD@72mpg.
85MudMonster
October 29, 2007, 07:49:43 pm »
Cool. I'll have to make sure to invest in that before I start to put the lift on it. Thanks for the info.
Dan
