Author Topic: Which is the outlet line on the transmission?  (Read 4130 times)
Offline team39763
« on: November 05, 2007, 06:41:51 pm »
I'm setting up an external filter and cooler for my TH350, and I need to know which is the outlet line...top or bottom(on trans)?  Also, if ya'll would happen to know what size fittings are used for the trans coolant lines(on the trans)?  Thanks.
Offline team39763
Re: Which is the outlet line on the transmission?
« Reply #2 on: November 05, 2007, 09:25:22 pm »
Thanks Vile.
Offline DnStClr
« Reply #3 on: November 10, 2007, 08:32:02 pm »
Here's another link- with fitting sizes.
http://www.tciauto.com/Products/TechInfo/cooler_fittings.asp
One way to determine npt fitting sizes- measure across the threads and then subtract 1/4 " and you have the size of the pipe or fitting.
« Last Edit: November 10, 2007, 08:37:28 pm by DnStClr »
Don
87 Chevy Silverado
