Author Topic: EGR?  (Read 15967 times)
Offline 81Cheyenne
EGR?
« on: November 21, 2007, 03:51:30 pm »
I recently bought a used Edelbrock Performer intake to put on my 305.  It's the spread-bore version with EGR.  Most of the emissions related connections have already been eliminated and at some point in the future I'll be changing over to headers as well.  Is s there any advantage (or disadvantage) to blocking off the EGR on the intake?  There is no emissions testing in this state so that's not a problem.  I also noticed that there are 2 holes cast in the floor of the plenum chamber, would I need to plug these as well?  Oh, sorry, It's on an 81 C10 LWB 2WD.
thanks.
Offline werewolfx13
Re: EGR?
« Reply #1 on: November 21, 2007, 05:34:20 pm »
Having the EGR valve there and functioning keeps cylinder temps down a bit i think, but I've never had a problem with em blocked off..one of the POs of my truck blocked mine off, and I blocked off the one on the '84 I used to have because it was in the way where I wanted my hand choke brackets when I put a Holley on it.
Chris
'83 Chevy c10 Silverado SWB
Re: EGR?
« Reply #2 on: November 21, 2007, 07:11:43 pm »
No problems blocking it off...Go for it.
Offline KojaK 79k10
Re: EGR?
« Reply #3 on: November 23, 2007, 03:48:09 pm »
if pieces of the system are missing then go ahead and block it off but what wearwolf said is correct. the cylinder temperatures are supposed to be lower. the purpose of the EGR is to re burn unburned hydrocarbons to reduce emissions. In these older systems it neither helps nor hurts to have it there.
77 Chevy swb "race truck"
*SOLD* 79' k10 Silverado SWB "Kojak"
truck is gone but not forgotten, worst thing I ever did was sell this truck and I regret it everyday.
Offline cline100
  • New Users
Re: EGR?
« Reply #4 on: November 23, 2007, 06:48:06 pm »
You can't reburn what's allready been burned. The purpose of the Exhaust Gas Recerculation system is to reduce Nitrogen Oxide, or NOx Emissions. It does this by reducing the amount of oxegyn in the cylinder by sending in exhaust gasses, thus reducing NOx, which form when fuel is burned at high temperature. Removing the system won't nescessarily cause problems, but in order to compensate, you'll want to run just a little bit rich, and use fuel to keep your cumbustion temperatures down. Of course, this won't help emissions at all, but it will keep your engine running longer.
Re: EGR?
« Reply #5 on: November 23, 2007, 07:02:00 pm »
Yes EGR is an inert gas. It will not reduce HC emissions only Oxides of Nitrogen. NOx gasses are produced when combustion temps exceed 2500°F but if your engine is producing high levels of NOx I would suggest a good decarbonizing and check of the ignition timing and a/f ratio. EGR will drastically reduce engine power so if you're hot rodding it up just unplug it and you'll see a huge difference without it.
Offline 81Cheyenne
Re: EGR?
« Reply #6 on: November 27, 2007, 12:31:53 pm »
Cool.  What about the holes inside the plenum?  Do I need to plug those somehow or are they ok just left alone if I take off the EGR?
Re: EGR?
« Reply #7 on: November 27, 2007, 03:31:35 pm »
You can actually just leave the valve on and remove and plug the vacuum hose. I have a bunch of EGR block off plates if anyone needs one.
Offline 81Cheyenne
Re: EGR?
« Reply #8 on: November 28, 2007, 07:57:23 am »
I'm interested in one of those plates.
Re: EGR?
« Reply #9 on: November 28, 2007, 07:00:29 pm »
OK I have 6 of them left
Re: EGR?
« Reply #10 on: November 29, 2007, 09:53:57 am »
You don't have one for a TPI do you?
Re: EGR?
« Reply #11 on: November 29, 2007, 06:00:51 pm »
If it'll fit your manifold you're more than welcome to one. I've had these for years. I had the machine shop make me a bunch of em...
Offline DnStClr
Re: EGR?
« Reply #12 on: November 29, 2007, 08:53:35 pm »
If you get Pugsy to make em they'll be stainless and probably coated with polished copper. Ha!
Don
87 Chevy Silverado
Offline JJSZABO
Re: EGR?
« Reply #13 on: November 30, 2007, 11:20:02 am »
LOL  :D
Jeff
86 Chevy C-10
350, TH400
Re: EGR?
« Reply #14 on: December 07, 2007, 07:05:23 am »
I dropped it in the mail 4 u yesterday so be on the look out for it.
