Author Topic: wont run right...  (Read 12093 times)
Offline 79shortbed
wont run right...
« on: November 23, 2007, 10:35:15 pm »
heres the thing, i think it might be over carbed...
i drove it all day, and some times when i step into it it bogs down then clears out and pulls hard... 50deg out side
WELL tonight a get in it pull it out of the garage and its starts right up, idles fine, drive normal...40ish deg out side
i get to the store turn her off and come back about 10min later start her up drive away and she does not want to run, bogs down, wants to die and barely stays running i step into it she's clears out and runs fine but goes back to doing the same ol' shoot...
help me out
Offline nova801428
Re: wont run right...
« Reply #1 on: November 23, 2007, 10:51:13 pm »
When is the last time you replaced your fuel filter?
1975 Chevy k20 6" lift 35" BFG MT's True Dual Exhausts Radical Cam
1980 GMC 2500 Parts Truck
Offline 79shortbed
« Reply #2 on: November 23, 2007, 10:55:18 pm »
yesterday, the normal chrome with clear housing.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: November 24, 2007, 01:11:48 am »
choke adjustment, vacuum leak (something may have gotten disconnected), timing--distributor loose?, if you have a cat converter, perhaps it is clogged, EGR clogged?....just a few things to throw out there.
Offline 79shortbed
« Reply #4 on: November 24, 2007, 07:30:43 am »
removed choke
no cats
no egr
im going to look for vacuum leaks and mess with timing
« Reply #5 on: November 24, 2007, 07:46:33 am »
1st off what do you have? What carb do you have? What engine do you have? What ignition system do you have? What's your timing set at? etc...list details.
It sounds like your float is sticking.
Offline 79shortbed
« Reply #6 on: November 24, 2007, 08:04:36 am »
late model 350 with sepintine belt, 700r4 trans.
performer intake
holley 670dp street avenger, electric choke removed
roller rockers
nice lil cam
long tube headers
flowmasters
stock hei,plugs,wires,coil
timing was set by ear, theres no timing tab. BUT it was set when the carb was messing up so its not to perfect.
im thinking it all has to do with the carb...
« Reply #7 on: November 24, 2007, 08:24:58 am »
#1 nail down your timing... find TDC #1 and make a timing pointer or put one on and refernce that with the balancer or make your own mark.
make sure your advance is working correctly. If you are running a stock HEI go through it. This is probably the most over looked thing ever. Install a decent advance curve kit and not sure how big your lil cam is but try running the vacuum advance to full vacuum. That should help with a more stable idle and better throttle response.
It sounds like the float is sticking in your carb. After you straighten out your timing if it does it again take a screwdriver handle and tap on the side of the carb, if it straightens out take the carb off and rebuild it. Replace the needle and seat.
Offline 79shortbed
« Reply #8 on: November 24, 2007, 08:36:25 am »
im thinking about buying a summit hei, any luck with those?
 i will look at all the things you said...
im about one trip to the parts house away from running TBI lol
« Reply #9 on: November 24, 2007, 08:53:06 am »
The GM HEI is a great distributor when compared to breaker points but that's about it. If you bought an MSD or the like you would be simply amazed at the difference. I kid you not. It should be a mandatory upgrade for anyone looking to get better performance. I'd do that before many of the other mods people tend to do first.
I've always used MSD and had good luck can't speak for the less expensive units but good luck!
Offline 79shortbed
« Reply #10 on: November 24, 2007, 06:12:46 pm »
i did a complete tune up, still runs like crap. i went in and read my holley manual...
do out and mess with it, now its puking fuel out of the front vent tube.
Offline 80stepsideguy
« Reply #11 on: November 24, 2007, 06:45:33 pm »
what style holley you got?I got a brand new kit in the box and a prtial kit in the box that only had soem gaskets removed but if your interested i`ll make ya a deal for the 2 .
thanks
pat
p.s. if you want PMme and i`ll get you pics n part numbers for the 2
1998 Chevy 1500 S/B 2wd
Offline 79shortbed
« Reply #12 on: November 25, 2007, 07:45:52 am »
its a 670 street avenger
pm sent
« Reply #13 on: November 25, 2007, 10:09:04 am »
Like I said your float is sticking. try tapping on the carb
Offline ccweber
« Reply #14 on: November 26, 2007, 11:01:56 pm »
might wanna try adjusting your float. i have had the same problem with my old truck, not sure the quadrajet is anything similar to what you have, but my float was too high on my quad and was open just a little bit and is was running doggy, kinda sounds like what your problem is. other than that all i could think of it being is your vacuum advance not being hooked up properly..... then again it could be you have some loose debris in the bowl of the carb and it is causing blockage.
