Author Topic: motor swap  (Read 4335 times)
Offline 9d6ss
motor swap
« on: November 29, 2007, 02:54:30 pm »
Hey guys, i'm pretty new to the forum and our trucks.  I just picked up a 73 shortbed and want to swap to an injected motor. I have access to all sorts of 350's. Which years would be easiest to swap over from my carbed motor?
Re: motor swap
« Reply #1 on: November 29, 2007, 03:58:44 pm »
Are you talking about the whole system? EFI included?  That is kind of a loaded questions as it depends on what you mean by easiest.  Any 87-99 Vortec will bolt up, but you need the ECM, harness, EFI fuel lines fuel pump, etc.
Have you looked at these threads:
6.0L/4L80E to 80's pickup http://forum.73-87chevytrucks.com/smforum/index.php?topic=5225.0
Carb to TPI on 78 Jimmy: http://forum.73-87chevytrucks.com/smforum/index.php?topic=5737.0
Offline 9d6ss
Re: motor swap
« Reply #2 on: November 29, 2007, 09:09:57 pm »
The whole tpi motor, I a few donors to choose from.
Offline DnStClr
Re: motor swap
« Reply #3 on: November 30, 2007, 10:16:52 am »
If you plan on upgrading to tpi, everything changes. You also have to install an ecm, a different fuel delivery system, electronic transmission, different gauges, and a new exhaust. Lots of work there.
Don
87 Chevy Silverado
Re: motor swap
« Reply #4 on: November 30, 2007, 10:31:07 am »
You don't need an electronic trans, you can use any trans you want, you can keep the current gauges also, Unless you are swapping to an LT1 you can use the stock manifolds too.
Offline 9d6ss
Re: motor swap
« Reply #5 on: November 30, 2007, 07:50:57 pm »
I just got in a 90 blazer w/ a F.I 350. Can I use the dash harness and everything elso to swap it over?
Re: motor swap
« Reply #6 on: December 01, 2007, 10:19:11 pm »
Yes you can do that.  Pull the whole harness out any you will basically be updating the wiring on the truck at the same time.
