Author Topic: pick-up coil  (Read 4540 times)
Offline stevens
pick-up coil
« on: December 06, 2007, 07:25:15 pm »
how do i get it off?? 78 p/u 355
Thanks
Re: pick-up coil
« Reply #1 on: December 06, 2007, 07:30:45 pm »
 ??? You mean the pick up coil? lol
Pull out the distributor. Pay attention to where the dot is on the drive gear. It should face the same direction as the rotor points. Drive the roll pin out of the drive gear and remove it along w the washer. Remove the pole piece. The p/u coil is retained by a metal clip. Now is a good time to clean the grooves on the pole piece and pack the grooves with a thin coat of white grease before reassembly.
Offline jonkmbll89
Re: pick-up coil
« Reply #2 on: December 06, 2007, 07:39:47 pm »
It is real easy to do.
Offline stevens
Re: pick-up coil
« Reply #3 on: December 08, 2007, 02:03:24 pm »
any hits on how to get the drive gear out?
Re: pick-up coil
« Reply #4 on: December 09, 2007, 09:46:43 pm »
There is a roll pin in the gear, you need to press it out.
Offline DnStClr
Re: pick-up coil
« Reply #5 on: December 12, 2007, 12:21:13 pm »
Stevens I hope I'm not misunderstanding- are you asking how to get the gear off the shaft, which the guys have already answered, or how to remove the entire distrib. shaft from the engine? If that's what you're having trouble with, you can squirt penetrating oil around the drive gear to help loosen it up so you can pull it out of the engine. And then if you need to, you can use an oil filter wrench or a strap wrench around the distrib. to turn it and help the oil loosen it up. The shaft pulls straight up out of the engine.
Don
87 Chevy Silverado
Offline stevens
Re: pick-up coil
« Reply #6 on: December 18, 2007, 07:12:06 pm »
yah i got it replaced thanks
