Author Topic: balljoints  (Read 4195 times)
Offline hotrod24
balljoints
« on: December 30, 2007, 08:10:13 pm »
hey i have a 78 chevy truck and wanted to know how to check my balljoints and see if thay need replaced
« Last Edit: December 30, 2007, 08:12:49 pm by hotrod24 »
1978 pontiac grand prix...
Offline greenmonster
Re: balljoints
« Reply #1 on: December 30, 2007, 08:46:02 pm »
Jack it up and grab the tire in the 12 o'clock and 6 o'clock position and see if you can wiggle it.
Re: balljoints
« Reply #2 on: December 30, 2007, 10:57:03 pm »
If your truck is 2wd you will need to jack it up underneath the lower control arm to unload the load carrying balljoint (do not jack it by the frame). Then insert a prybar underneath the tire and lift up and down while observing the balljoints.
If it's 4wd you can jack it by the frame or by the axle.
