Author Topic: spark plugs  (Read 10337 times)
Offline mikewb
spark plugs
« on: January 08, 2008, 07:05:37 pm »
what is the problem if my spark plugs have a kind of orange glaze on one side of them
Offline mikewb
Re: spark plugs
« Reply #1 on: January 08, 2008, 07:08:54 pm »
kind of pink i guess
Offline greenmonster
Re: spark plugs
« Reply #2 on: January 08, 2008, 07:12:40 pm »
When was the last tune up. Do you us any aditives in your gas.
Offline mikewb
Re: spark plugs
« Reply #3 on: January 08, 2008, 07:19:24 pm »
its been a little while but not that long and i dont drive it daily. and no ive not poured anything in it since these plugs. been having small problem. feels like a missfire. soo just checking to see.
Re: spark plugs
« Reply #4 on: January 08, 2008, 07:22:11 pm »
It may be running lean.I have never seen orangeish or pinkish color on plugs.
Re: spark plugs
« Reply #5 on: January 08, 2008, 07:23:05 pm »
Did you just put the carb on or do any other changes.
Re: spark plugs
« Reply #6 on: January 08, 2008, 07:23:49 pm »
post pix. Are all of them the same?
Re: spark plugs
« Reply #7 on: January 08, 2008, 07:25:05 pm »
The real help has arived. VILE!!
Offline mikewb
Re: spark plugs
« Reply #8 on: January 08, 2008, 07:30:23 pm »
well i pulled the front one out of each side. and they were the same didnt pull the others out. And no i havent made any changes. i just put a new trans in and every since then it hasnt ran right
Re: spark plugs
« Reply #9 on: January 08, 2008, 07:38:33 pm »
when you put the new trans in did you tilt the engine unsupported? Maybe the distributor cap hit the firewall (crack)? did you knock a vacuum hose off?
Offline mikewb
Re: spark plugs
« Reply #10 on: January 08, 2008, 07:49:35 pm »
ive pulled the cap and everything everything looks legit. but at idle it  has a small shake not real noticeable. but going down the road if i punch it under load it misses and sometimes backfires
Re: spark plugs
« Reply #11 on: January 08, 2008, 07:53:44 pm »
and it's ever since you replaced your trans? Double check your cap and your connections/wires
Offline mikewb
Re: spark plugs
« Reply #12 on: January 08, 2008, 08:14:52 pm »
i dont that. pulled each one checked em. pulled the cap checked for cracks cleaned it out. checked rotor.  im starting to think it might be my carburetor but dont know a lot about this edelbroc
Offline Fordeatinz71
  • 78k miles and counting
Re: spark plugs
« Reply #13 on: January 08, 2008, 10:58:00 pm »
honestly it sounds like a vacuum leak.  you should try spraying starting fluid (or something similar) around the base of the intake...see if the idle changes.  i'd bet it's a blown intake gasket...maybe around the back of the motor...i'd spray on the intake as well, to make sure there's no hairline cracks that you can't see with the naked eye...
Offline mikewb
Re: spark plugs
« Reply #14 on: January 09, 2008, 03:50:23 pm »
ok ill check it out. now that you say something when i was washing the motor i noticed it change tone.
